2012/03/25
I tried installing the adb drivers for my arnova 7 g2 but I always get the error "The hash for the file is not present in the specified catalog file. The file is likely corrupt or the victim of tampering"
I've downloaded the drivers from the arnova website and from the google dev website. None of them works. I also added the 0x0e79 to my adb_usb.ini file. I don't know what i'm doing wrong here...
Maybe you can have a try on our package for ADB:
http://www.arctablet.com/blog/featured/adb-driver-update-for-archos-arnova-devices/
try to use superoneclick or unlock root to force install drivers
Another option is PDANET: http://www.junefabrics.com/android/download.php
Vrailink said
Okay tried unlock root, but the program keeps asking me to install driver but when I click yes it just asks the same thing over again...
Superoneclick gives me "Unknown error (0x000024b)
That error appears very often on windows xp
Another methos is to copy in system32 this files
WUDFUpdate_01009.dll
winusbcoinstaller2.dll
WdfCoInstaller01009.dll
i can try to help you tomorrow if you want via team viewer.
Quite possibly considering you are running a beta version of Windows 8
***edit***
This method works great, even when running the ICS rom for the AN7G2: http://www.topnotchtablets.com/installADBdriver
95 Guest(s)
Devices in use: Desktop (80), Phone (14), Tablet (1)
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
pablovs
