2013/02/18
hello,
due to a bug problem with the tablet, I tried to flash with a custom firmware, but it still bug.
I have to return it for repair, but for this, I need to restore the original firmware. But only flashing by SD card works now, and no more with the manually update.
Pity, someone are there a original firmware compatible with flashing by SD card?
I need your help!
I really need your help !
Beside the original firmware which is available on arnova`s website, we don`t have another one
http://arnovatech.com/support/firmware/3/arnova10dg3/121031/ARNOVA_10d_G3_20121031.zip
2012/12/06
hello,
I need your help!
ARNOVA 10d G3 ORIGINAL "STOCK ROM"
Android 4.0.3 v1.2.0 2012-10-31-20120824.104231 (Pre-Rooted)
2 parts
for flashing by SD card
WARNING: The installation will delete ALL installed apps and user data!
BEFORE installing absolutely secure important data from / mnt / local!
    The two files with 7-Zip, or any other program that can handle them unpack.
    Formatted the extracted content to a FAT32 microSD card copy (IN THE PARENT DIRECTORY!).
    The tablet with the power supply connect.
    The tablet off (Power button long -> "Shutdown" menu).
    The SD card in the tablet insert.
    The tablet on again.
    Now is automatically loaded into the firmware installation.
    While the process is NOT the tablet off and remove the SD card NOT!
    Once the process is complete, the tablet asked to refer to the SD card.
    Remove the card and the tablet will automatically reboot into the installed ROM.
81 Guest(s)
Devices in use: Desktop (71), Phone (10)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
