2013/06/29
Right I have a bit of a problem that I hope someone can help with. Sorry if its a bit long winded.
I bought a 10D G3 from ebay. I charged it up for the first time and by accident I knocked and slighty bent the bit that goes into the tablet. Â Straightened it up, used the tablet (un plugged) and was very pleased with my good buy.
When I went to plug it in to re charge, the pin broke so I ordered a replacement charger. This duly arrived but didn't charge the tablet. My OH took the tablet apart and the pin inside had broken. He soldered it back but we aren't sure if it is working or not.
Should both the red and green light flash intermittently when charging or should it be just the red light on? or the green? Â
All it does at the moment is the red light is on for a couple of secs, then the green comes on for a further couple, green goes out followed by red and the battery icon appears in the middle of the screen and is not filling (to show charging).
Thanks in advance.
69 Guest(s)
Devices in use: Desktop (61), Phone (7), Tablet (1)
georgicaa97
kkn
LatifMohammadi
arthurmax01
yung1961
ondateste
