2012/12/21
Hi friends
Please tell me if I can help / advise on the following problem?
I have a problem when you restart / start / unlock the tablet from sleep mode, after pressing the buton ,tablet immediately automatically restarts?
Any ideas why this happen? how can I fix the problem?
And when press on-off buton apear menu and select the tablet it does not stop (shutdown) but restarts automatically.
I did factory defaults and put the original firmware Arnova again but to no avail.
best regards
daniel.
Activate usb debugging, and use adb logcat to see what is generating the reboot.
2012/12/21
I do not think I know something, because suddenly closes tablet and I think that data is lost when they give restart.
I tried the application on you but I do not see anything in that log.
What other choice do I have?
Flash back the stock firmware again, do a factory reset.
2012/12/21
I did this 2-3 times no result
I changed the original firmware arnova with firmware created by Doman 75 (Custom Firmware 4.0.3 V1.5 with Win8 Metro UI) was installed without errors but I have the same problem when I try to wake up from  sleeping the tablet ,in  about 4 seconds will restart automatically.(no eror,no mesage !)
Thats why i said, enable usb debugging, and use adb logcat, because there you can see erorrs that do not appear on the screen of the tablet.
neagudanyel
2012/12/21
Hi globula_neagra
After I struggled all day to find out what generates the problem, I managed to find these
problem was generated by asigment button, which from what I saw was wrong
I researched on the internet and with a little program ButtonRemapper - Beta v0.2.4, I was able to fix the problem.
http://forum.xda-developers.com/showthread.php?t=850464
From what I saw this program on-off button and a IIa command was assimilated after I canceled the second order everything returned to normal.
Now I can wake the tablet from sleep position without having to restart itself.
Know that your choice is very good. Thanks for your help.
all the best
daniel
2012/12/28
Hi Daniel,
as I have exactly the same problem and downloaded ButtonRemapper to fix it ...
Could you please advise, what exactly you did with this App?
I assume with on-off-button you mean the "Power"-button, correct?
Did you assign a new command ("wake" or "wake-dropped"?) or just started the App without changes (+ reboot)? The App complained that I don't have full root access - do I need this and how can I "root" the Tab?
Thanks a lot,
Jens
2012/12/21
jhartwig said
Hi Daniel,as I have exactly the same problem and downloaded ButtonRemapper to fix it ...
Thanks a lot,
Jens
Hi jhartwig
My recommendation is not to make more changes than necessary software. (I have not tried the rest of the options)
The only option I changed it "wake" and then I give restart the tablet.
I honestly do not know if you must have root access. but worth trying you have nothing to lose.
105 Guest(s)
Devices in use: Desktop (94), Phone (11)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
