Factory reset Arnova 10d g3
danijels
2013/08/21 - 08:32
Problem was started when I copy some mp3 songs from the SD card (ebay) to the device. Device freezes on Discovery SD card message (bottom right on the screen).First I reset my device then remove sd card and reset my device again but problem remains. So I decide to factory reset device completely.
I tried following instructions:
"Hold down the volume button + and press the ON/OFF button.
Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
1.Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
In the Android system recovery, select Wipe data/factory reset;
Select Yes –delete all user data.
Select Reboot system now."
but I do not get to the boot menu. My device goes through recovery 10 s on/off confirm procedure and stops in the wizard menu for entering the country without touch sensitivity.
So How to factory reset my device with success?
50 Guest(s)
Devices in use: Desktop (38), Phone (12)
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
hamishduke
