did some if you tried to alter the vold and swap the internal sd with the external one ?
2012/12/27
globula_neagra said
http://forum.xda-developers.com/showpost.php?p=34446563&postcount=41
http://forum.xda-developers.com/showthread.php?t=1410262
Would that work with this tablet? I will have a proper read later.
What is the best way to format the external sd and what file format?
I can't seem to be able to reflash my tablet. (I think I have reflashed it now)
I am trying those links will let you know if it works.
Okay here is where I am at. If I use the information in the above links I get the following. If I select the storage as Internal Flash(ROM) it installs apps but seems to install just to the internal sd even with the directory bind. If I however is I select SD Card they seem to install to external sd but some apps from the market either say they have bad manifest os can't install to sd card. Does anyone know how to fix this?
2012/12/27
I thought I would start a new post but it seems to be working.
I rooted my device with the firmware earlier in this post. I then basically followed this http://www.xperiablog.net/2011/12/12/link2sd-guide-never-worry-about-internal-memory-limits-again/ and also selected sd card as the storage in settings. seems to be installing to external sd for me.
2012/12/27
kev596 said
Hello, I made an error handling is now I'm stuck on the screen with the guy with a red triangle Adroid how I can do for my tablet be usable again thank you for helping me.
It took me a while as i had the same with a second tablet I have. I had to hold power + while pressing the power button. Still holding the power + button until it goes into recovery in which you press the power button to accept. It should then recover itself.
2012/12/28
hello, i think i have erased my stock rom and now i am on the screen with the red triangle when i try to get in recovery mode and than starts new without recovery option.
I have tried to install this Rom but during the installation i get an error:framework/w-load DDR3......bin not found can someone help me, how i can get any rom back to my 10gd3?
thanks a lot
2012/12/27
Ok so my first tablet seems to be working fine with the method I used. How ever the second one (which belongs to my brother) doesn't seem to want to install apps to the external SD. I done the method excatly the same on his tablet as mine but when the tablet turns off and on the apps disappear and have to all be reinstalled. On my tablet I do not have this problem.
2012/12/21
globula_neagra said
Stock firmware http://arnovatech.com/support/firmware/3/arnova10dg3/121031/ARNOVA_10d_G3_20121031.zipHow to install
http://arnovatech.com/support/firmware.html?country=ro&lang=en&g=3.1
This tutorial is available only if you install this firmware over the existing or the one that came from factory ,over this custom firmware version can not be put the version after Arnova website (I tried many times, error after restart,red triangle)
But worth trying and you.
45 Guest(s)
Devices in use: Desktop (40), Phone (5)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
