Arnova 10d G3 Custom Firmware 4.0.3 V1.5 with Win8 Metro UI and other
dashmaxi
2012/12/08 - 23:00
it does not work...
Crow103
2012/12/09 - 00:20
Same here :-(
 He starts to Recover, but stops with the Red Triangle >.<
I would love to use this CF but my WLAN didnt just work, because there are not the correct driver on the system :-(
Now my Tab is just useless with this firmware... and i cant get back to the original...
Maybe doman75 can say something to our problem...
dashmaxi
2012/12/09 - 00:48
Same as U but Wifi still ok
Griller_GT
2012/12/09 - 11:53
Hi. Has anyone managed to install the original firmware back into this tablet yet?  Confused
padre
2012/12/09 - 21:05
i installed this rom to my 10D G3, and all works fine, except there was a problem with gmail and gtalk. The programs were installed but with no icons. I resolved this with (gmail widgets.apk), and for gtalk (more icons.apk). This was the only fault.
So i've decided to stay on this rom, because it's more stable than arnova stock one.
regards
greencopper
2012/12/15 - 08:44
What benefits does this rom provide over the original one?
Is it possible to mount EXT devices with this rom?
alvess
2012/12/15 - 09:19
The most important benefit for me is that "google play store" works.
Unfortunately the USB host driver seems to be missing in this kernel.
So please if someone have the knowledge.... Wink
neagudanyel
constanta romnia
Forum Posts: 11
2012/12/25 - 00:39
Good question?
Installation went very well, but how to downgrade to original firmware Arnova ?
jason544
Forum Posts: 15
2012/12/28 - 04:25
I have flashed my tablet with the suggested Rom and also formatted the sd card. I set the sd card as the main storage in settings but keep getting couldn't I stall to use storage or sd card error
neagudanyel
constanta romnia
Forum Posts: 11
2012/12/28 - 07:37
hi jason544
I recommend you put firmware again.
jason544
Forum Posts: 15
2012/12/28 - 19:07
neagudanyel said
hi jason544
I have noticed that when I selected the external sd as the storage it lets me move the apps to the internal storage but not the other way round. Also is there any reason why the memory card has to have two partitions. I am right having o e as ext2 and one normal? Both are primary but not sure what size they were ment to be so gave half each for now on the 32gb memory card.
Just tried to reflash it but I can't get it to do it. I have put both the files from an10dg3 and booted up but it doesn't flash it just boots up normally.
Tarnatos
2012/12/29 - 15:46
does this custom fw have the original google contacts app included?
neagudanyel
constanta romnia
Forum Posts: 11
2012/12/29 - 17:41
Hi, does this custom fw have the original google contacts app included?
Hi Tarantos
This firmware comes with the following applications:
-agenda
-voice Search
-Downloads
-google talk
-messaging
But I honestly do not use them.
jason544
Forum Posts: 15
2012/12/29 - 20:37
I can't seem to refresh my tablet also the apps don't seem to run from the external sd card just from the internal one. Is there a tutorial or anything to follow apart from these posts? I may see if a mate at work can help as he is good with these things but would help if I had something to go on first.
neagudanyel
constanta romnia
Forum Posts: 11
2012/12/29 - 23:20
I recommend to get easily, and I tried and I did various tests but no results.
My personal opinion: This firmware does not support applications to run after external sd card.
regards
daniel
Currently Online: 5256makc
118 Guest(s)
Devices in use: Desktop (114), Phone (5)
5256makc
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
