Arnova 10d G3 tablet feedback with first users reviews
mannix
Italy
Forum Posts: 14
2012/11/22 - 19:51
I can do any kind of test, I will take all the risks :)
Thanks Received: 268
2012/11/22 - 20:12
install java jdk, android sdk
enable usb debugging
connect the tablet to the pc, install the adb drivers
learn how to use adb (watch some tutorials on youtube)
then type
adb shell
cat /proc/mtd
df -h
mount
mannix
Italy
Forum Posts: 14
2012/11/22 - 20:22
Will do it tomorrow, I'm going out for dinner now.
I have a pretty good knowledge on android/linux anyway, you can speak geek freely :)
2012/11/22 - 20:36
get the output of those commands first, and then we will see if we can get root using the procedure that you mentioned
then dump all the files from the tablet
then check if the tablet has bootloader (fastboot mode)
then create a custom system.img with gapps
and other stuff :)
then then then, so much usage of then then
mannix
Italy
Forum Posts: 14
2012/11/23 - 16:52
I can do everything up to creating the custom.img, but if you'll help I could manage it.
The rooting hack works flawless, already applied and verified. It works starting the tablet with the proper files inside the sdcard.
I will send you the output you need as soon is possible. Hope it's the same now that I rooted the tablet, if it's not I can reflash with the stock firmware.
The flashing can be done only thru sdcard, there's no "official" flashing tool available but from what I understood it looks ppl is using this tool to flash china tablets made upon the same platform:
http://www.topnotchtablets.com/LivesuiteInstall
I really don'y know how to check if it could work.
How do you wantme to dump all the files from the tablet? adb push? special tool?
I see for the Rockchip platform there's rkdump, but I guess it doesn't work for allwinner.
2012/11/23 - 17:02
share the output from
adb shell
su
cat /proc/mtd
df -h
mount
from what i know this tablet uses a via processor
you could check with antutu or other similar apps to see what processor is using.
Thanks Received: 3177
2012/11/23 - 17:10
LiveSuite program for Windows is made for Allwinner based tablets, usually A10 or A13 platform.
From what I understand, the 10d G3 uses a VIA processor, which is a different platform, so LiveSuite can't be used there.
mannix
Italy
Forum Posts: 14
2012/11/23 - 17:18
Forgot to tell the adb drivers works fine!
mannix
Italy
Forum Posts: 14
2012/11/23 - 17:37
I guess you are right, I wrongly supposed the the Allwinner A10 was a rebrand of VIA 8850.
Half specs sheets of Wondermedia 8850 tablets tells inside they have an Allwinner A10, I thought the 8850 was coming from the soc name.
2012/11/23 - 19:33
someone just posted a rooted firmware on the 10d g3 section, have a look, test it :)
but my advice is to make first a back-up of your current firmware, in case something goes wrong, you will have a back`up
mannix
Italy
Forum Posts: 14
2012/11/23 - 19:41
The shipping firmware is available on Arnova website, if that firmware is only rooted it's nothing more than I have now.
I will check anyway, thanks for the tip :)
franky384
Forum Posts: 14
Thanks Received: 4
2012/12/02 - 22:54
Search for rootburner, it worked for me without probs.
You can download here:
https://www.dropbox.com/s/g7fqodua9f3ur6e/RootBurner.zip
rars
2013/01/26 - 05:32
hy guys i m a sad user too.my frist prob it s the dooongle :my model it s in the supp list it turns green but no internet connection,i instaled a custom filmaware witch have mobile networks(how the f the original dosent?)
my second and bigest problem (hope someone can help me)when i plug on the device(usb cable,comp cable,battery) when i put my fingers on the display starts randomly to touch himself.the device is new so wtf.i need a solution not go back to waranty .thanks a lot mates
JEssicannn
Forum Posts: 252
2019/10/23 - 01:29
Currently Online: ri9000
72 Guest(s)
Devices in use: Desktop (67), Phone (6)
hamishduke
squal
squalangel
anqilan456
havetoregister
werasler
