sp_TopicIcon
The Recovery mode is not responding.
xsnowbellx
2013/03/05 - 03:30
i have a big problem, i want to try to build an own rom but by my Tablet is the Recoverymode not working.
If the Tablet is off then i press the Volume down button and the power button and after 10 seconds the Arnova logo appears. After a few seconds i come in the Recovery Mode?! (i am not sure that i doing it right).
In the top stands "Android System Recovery e3" and i have 5 Points there i can select but when i click on the volumen down buttons noting happen and when i click on the volumen up button the recovery menu disappears and appears. Only the Power button works correct.
I Hope someone can help me.
Thanks Received: 264
2013/03/05 - 09:36
Do you have a CWM recovery ?
xsnowbellx
2013/03/05 - 12:57
Yes i have a CWM . The device is still running. But i want a save mothode to recover before i try something.
2013/03/05 - 13:41
Well you need to configure the cwm buttons if you can not select nothing.
xsnowbellx
2013/03/05 - 17:52
Ok i misunderstood the question.
I have the original recovery on the tablet. I want to put the cwm on it but i dont know how and which i should take.
Maybe you know a good guide for this.
2013/03/06 - 10:47
There are 2 ways, either you use a rooted tablet and you flash the new recovery, via adb, either you use rockchip tool, and flash the new cwm.
xsnowbellx
2013/03/06 - 12:25
The Tablet is already rooted. Where i can find a Working CWM?
I have seen here the [MorkaMod][Android 4.2.2 full AOSP][All RK2918] and i want to try this. but i dont know how i can restore the tab if the rom is not working.
The other thing is that i be not sure i have a rk2918 board.
I have check it with Hardware Info and Smart System Info.
Hardware Info say's Device:Mw07
Smart System Info say's Hardware: sun4i
By a friend on the Tablet say Smart System Info Hardware: rk2918 ...
Sorry for the grammatical fault i am from germany :)
2013/03/06 - 12:37
I see that you are a starter in the world of Android, if what you are requesting now was feasible it would have been done by now.
When i first saw your topic i assumed that you already have a CWM, but actually you don`t and we don`t have either.
From what i remember Morka mention in that topic on what tablets that firmware works.
69 Guest(s)
Devices in use: Desktop (50), Phone (19)
abdouerr
shino246
sofia7777
chimo014
vishu bhatnagar
djwood1014
