sp_TopicIcon
Problem with model 10C G3
JLennon
2013/04/23 - 14:22
Hi guys,
I need your help. I have this model and i like it. Now i have a problem. I dont know the reason, but now i need to type a password to access in it. What the fuck?
I tried to restore it with "system recovery" but no way. I cant use the volume buttom to choose the options. Just reboot. ¿Why?
I called to support service and they are a little geeks. They said that i need to send it to support to repair it... What the fuck again? There isnt firmware in the official website to use. I dont know what to do. Can you help me to fix this problem? I am really confused...
Thanks for all.
abcchoier
2013/08/04 - 15:14
I also having the same problem, did you get your resolved?
poohfg
2014/02/17 - 04:33
I've searched high and low over the net and have found very little info in regards to the arnova 10c g3 i recently was given one that powers up but is password locked as well, when i go into the recovery mode this tablet has the same issue the volume buttons will not let you scroll to select the factory restore option, all you can do is reboot. has anyone found a way to restore this tablet to factory setting or some kind of master password code to get into the tablet, or is this just a worthless piece of junk now ??????? I can hook the tablet up to my pc and the adb recognizes it but i cant obvious change it into any sort of debugging mode so i have no idea if there is any work around's......
Any info on this would be greatly appreciated including possibly a repair shop in the us that maybe reasonable if they can wipe and reinstall the original firmware as i cant seem to find that anywhere on the net either.
Currently Online: Azabatxe1
143 Guest(s)
Devices in use: Desktop (138), Phone (6)
jacksonrid
usdown
ibob64
