2013/01/19
Buongiorno
mi è stato regalato un Arnova 10c g3,
non avendo potuto controllare subito il tablet ho dovuto aspettare 3 settimane
prima di poterlo utilizzare.
Una volta utilizzato mi sono reso conto che il tablet non funziona;
- si riavvia spesso da solo
- perde la connessione wi-fi
- si smonta la micro sd ogni volta che va in riposo il tablet.
Vorrei sapere se qualcuno ha di questi problemi e come li ha risolti
Grazie
Good morning
I was given an Arnova 10c g3,
not having been able to check immediately the tablet I had to wait 3 weeks
before using it.
Once used, I realized that the tablet does not work;
- Restarts often alone
- Loses the wi-fi
- Dismantling the micro sd every time he goes to rest the tablet.
I would like to know if anyone has these problems and solved them as
thanks
2013/03/01
Try to install "REGPON wifi keepalive" from the Playstore. It should fix the wifi and sd card problem. Nice other effect is the Tablet awake faster from the standby. But the bad part is the battery goes really fast empty. By me lost the battery 50% in 10 Hours standby.
I guess the problem is that the tablet in the standby the cpu stopped.
71 Guest(s)
Devices in use: Desktop (63), Phone (8)
kuzin
Dag58
montolla
portvein
POELE
hststs44
