sp_TopicIcon
Fixing SD permissions issues
sirarthur
2013/01/18 - 17:36
Just fixed my Arnova 10c G3 and decided to share the method I use in case someone is experiencing the same issue.
Problem:
- Most of the applications aren't able to write to SD card, exception in my test to ES Explorer
Needed:
- Rooted tablet. The drivers provided in the root topic work just fine and UnlockRoot can root the tablet.
Solution:
Edit /etc/permissions/plataform.xml
Locate: WRITE_MEDIA_STORAGE xml entry and add to the xml tree:
Under: <group gid="sdcard_rw" />
Add: <group gid="media_rw" />
reboot your tablet and your SD card will be fine.
archoanarcho
2013/02/04 - 10:24
This method works fine! Now I can use my extSD for work. Edit, write and delete documents and other stuff on my 16GB SD card :)
Rooted Arnova 10C G3
55 Guest(s)
Devices in use: Desktop (51), Phone (4)
