2012/01/04
http://arnovatech.com/products/g2/arn_10b/specs.html?country=ru&lang=en
Not sure if this a new tablet, but very confusing to see forums for G1, G2, 10b, but nothing that says 10b G2, so I'm not sure where to go to look for info and ask questions.
As of now I don't even see firmware downloads from the Arnovatech.com website, so maybe that is also a bad sign? 🙁
I had an issue earlier where the browser just stopped working - it was almost like the website created a popup (even though popup blocker is enabled) and I couldn't scroll right, left, up or down to find a way to close it out. It looked like a popup as I could see the top 1/2 of the address bar on the screen - touching it brought up the address bar and I could enter in a new address, but nothing ever loaded.
I rebooted the tablet and then couldn't get it to connect to my wireless network - removed and recreated and still not able to connect - said it was connected, but wouldn't lease an address from DHCP.
I was going to perform a reset on it, but wanted to see if I could copy the downloaded file apk off of it (have about 7 games and apps I downloaded and figured it would be easier to copy them for reinstall.....nope, can't find them on the device).
Anyway, after not messing with it for about 2 hours it is now working fine. I went to the site to see if there was a newer version of firmware out, but just like this site, I see listings for G1, G2, and 10b, but not 10b G2.
2011/12/10
Post and use the Arnova 10 G2 forum. This is where everyone is talking about the 10b G2. Admin may make a sub forum if enough talk is generated specifically about the 10b G2.
There is no firmware available for the 10b G2 from Arnova yet. We are hoping someone will do a ROM dump so we all can have one when needed.
Bob
2012/01/04
Thanks, that's where I'll look for all the stuff. Just figured the G2 was for 2nd generation, and since 10 and 10b appear to be different, the 10b forum might make the most sense.
Not a bad little tablet for the money, even with all the limitations.
Bob
61 Guest(s)
Devices in use: Desktop (55), Phone (6)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
