usb to pc connection
TheSonic892
Green Hill Zone
Forum Posts: 37
2013/04/10 - 10:45
TheSonic892 said
Also, Is there a place specifically designed for arnova micro usb repairs because I diagnosed my tablet and managed to find that the micro usb pin had broken from its original position
Dont worry, I managed to get my tablet fixed, but now is there a way to easily connect to usb keyboards that are HID?
My Arnova 10b g3 specs:
1gHz of ram, a rockchip 2918 processor
8gb of flash storage
1 microSD slot
4.1.1 Jelly Bean
BluebellOMG
2013/08/01 - 15:10
it doesnt work at all nothing works so this means that we cant wacth dvd by the usb i might aswell give it back to argos beacuse this isnt helping at all. do you if their is a setting we need to do to make it work or is their a setting for the computer to work.
my pc is a old one its a vusys and a windows 7 could it be because of that.plz reply to me once u know the answer thanks any way for some of the tips though but ive tried 5 usb s for my arnova 10b G3 and no signal or connection.
do u have one any way or are u guessing what we should do.Because if u dont then please dont think your a expert.inless u have examed it before.
155 Guest(s)
Devices in use: Desktop (145), Phone (10)
