update versions
zaphodbeeb
2013/08/26 - 13:56
got myself in a bit of a mess here. I am confused as to what the latest version of the custom rom is. I now suspect I have flashed an old version, and this is shown as build Oma JB v1.2.2 05.10.2012.
I have the capacitive version of the 10b g3.
I also applied some of the other fixes to the install (services.zip and tun.zip).
Am I on the latest version and if not can where can I download it. Also, will I have to reapply the above fixes (or are they incorporated in the latest version).
One last point, to say thanks. The version that I have installed makes the device much better, and I appreciate the work thats gone into it.Thank you.
regards
ZaphodLaugh
2013/08/26 - 22:03
It's been a while without updates on the Arnova 10bG3. We have one in the works similar to our last custom firmware for the Arnova 10G2 which is based on Crew RKTablets's RK29 AOSP 4.2.2_r1 Test Build v1.3.
I can't give any release date, will be finished when time permits.
zaphodbeeb
2013/08/26 - 23:33
Cool,
I'll watch out for it, and thanks again.
regards
ZaphodSmile
66 Guest(s)
Devices in use: Desktop (61), Phone (5)
hans41
rickybk
soniya07
ironmangitar
