2013/06/21
HI the knowledgeable ones..... after a little advice please
I have a 10b G3 that had the screen shattered - powers up but bad as you can guess
I bought another off of ebay that had software probs for spares and screen worked
I have swapped over the boards and wired it all back up but now I get nothing -
H ear the unit doing a few clicks n stuff when power hit and the screen seems to dimly back light but still nothing. but this is on both units the same even the cracked screen version with the iff board in. I could at least see the arnova boot screen before
On supplying power I get the red charging LED on
I have gone through all cables and everything seems as it should be
any ideas plesae to go forward other than scrapping them
thanks
do you get any reaction when you connect them on a computer ?
2013/06/21
No the PC does not see anything
if i connect the USB and hit the power key twice I get the same as with the power in the screen changes shade of dark grey as if its trying to do something and a few click from the speaker
I have metered the batteries and they are both putting out around 3.5v
2013/06/21
OK put them back together as original and let them charge over night
Both booted to the original state ...
one unreadable screen
other locks at arnova boot
swithced boards over again and all booted as expected the scracked screen version is now up and running ok
weird but got there
thanks
54 Guest(s)
Devices in use: Desktop (49), Phone (5)
