did you try to reflash the tablet ?
did you use the upgrade or the restore option ?
2012/07/24
all night I was struggling with it and I noticed that there is a reason.
This firmware has a bug with battery (needed during start after 20 seconds, plug in the charger) and then automatically turns the tablet.
Firmware is still jedem bug Explorer it does not work.
More errors have not noticed.
Thanks for your help.
Try this then
handsomedude said
Hi all.
Ive flashed this and has the same problem.
easy way past it is as follows
Flash as normal and tablet will reboot and get stuck on arnova screen.
unplug usb and power cable
use pin and reset the tablet in the reset hole by the sc card slot.
arnova will pop up and after about 10 seconds arnova title will flash off and on,
Now count to 10 and plug in charger. screen backlight will illuminate and the tablet boots fine
has to be done like this every boot!
JCH3252Most Users Ever Online: 749
86 Guest(s)
Devices in use: Desktop (75), Phone (11)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
