Safe to upgrade firmware?
Rozza
2012/08/03 - 08:52
Hi all
New to tablets so this may be a daft question. Rooted my tab succesfully
using the arctools app.
There's an upgraded version of the firmware on the archos website, if I were to install this, would it unroot my tab or just overwrite the OS?
Regards
Thanks Received: 3169
2012/08/03 - 08:56
Where do you see a firmware update for the Arnova 10b G3, I can't find any on Arnova web site.
Updating the firmware with a newer firmware from the manufacturer usually make you loose root and all the installed files.
Depending on the device and how the update is made, it's sometimes possible to keep your installed apps data.
Rozza
2012/08/03 - 17:48
You know I'm not sure that it was a newer version now. I'm used to pc's checking for you so didn't think to double check.
In that case, how do I upgrade this rooted version in future? Just watch this site?
Cheers
Currently Online: Djomla88
90 Guest(s)
Devices in use: Desktop (78), Phone (11), Tablet (2)
Djomla88
darkfly13
SONNY4669
borodachuk
h10101010
Vlad7Serg
Topics: 6011
Members: 260690
