QR reader
wazboy
2012/07/30 - 17:59
Hi first posting from me. First off a big thanks to this forum, I followed the advice for accessing google play, as I am computer iliterate I found the advice very straightforward and it worked for me.
Downloaded 3 different qr readers but keep getting the message that they could not find the camera any help out there on this problem please.
Wazboy
Sengadog
Forum Posts: 33
2012/07/31 - 12:17
Nearly all barcode scanning apps require a rear facing camera that is why it says it is failing. If you do a google search you will find some developers have versions that will work now with forward facing cameras with varying results as the front cameras are such low resolution.
wazboy
2012/07/31 - 14:10
Hi Sengadog, thanks for the reply.
Waz
93 Guest(s)
Devices in use: Desktop (89), Phone (4)
asgard2701
Rob_nl
shadowlabs
grot
techrey
mickey2669
Topics: 6028
Members: 261271
