Internal memory storage
Related Tags
Killyox
Forum Posts: 36
Thanks Received: 7
2012/07/27 - 11:33
Hello, I have an Arnova 10b G3 with 4GB internal memory, and I have (like everybody I think) :
- My 1st little question is : Total space : 2.06GB !! Why 2.06 ? I have a 4GB tablet...
- But my real problem is : 312/512MB for application... Why is there only 512MB for apps ? Isn't there a way to extend this to the 2.06GB ? (Or better, to the 16GB SD card). Because I only use this table for trying apps or games, so 512MB is too small for me. I knew I may have problem installing apps on the SD card when I bought it, but I thought I could at least install apps on my 4GB internal memory :(
Does anybody knows how to extend the memory for my apps ?
Thanks !
2012/07/27 - 15:26
Killyox
Forum Posts: 36
Thanks Received: 7
2012/07/27 - 16:44
Ah, nice ! Thank you for your answer ! i'll try to install this custom firware as soon as possible.
But I have a little question. If I flash my tablet, I'll lose all my data, right (savegames, pictures, videos,...) ?
Is there a way to save those data ?
Thanks Laugh
Killyox
Forum Posts: 36
Thanks Received: 7
2012/07/28 - 15:13
The answer is "Yes"... I lose all the data ! But thank you very much, I now have 0.90GB memory for my apps ! It's not as big as I wished, but it's better. Smile
And Android Commander is now my big friend ! Thanks to it, I managed to save my apps and my data.
Now i just need to find how to reinstall my data without making my games crashing ! Laugh
Killyox
Forum Posts: 36
Thanks Received: 7
2012/07/28 - 16:46
Ok, i found how to get back my savegames without crashing my apps.
I just didn't copied the backuped files in the "cache", "databases" and "lib" folders.
Now everything is ok ! Thank you again Admin for our help ! Kiss
78 Guest(s)
Devices in use: Desktop (63), Phone (15)
chimo014
vishu bhatnagar
djwood1014
4ipolino
thomashansmuller11
abro
