[ ROM ] Custom firmware update 0.42 for Arnova 10b G3 ICS (Google Play, root and Face Unlock)
Thanks Received: 3169
2012/07/05 - 11:00
A few users reported calibration problems on the Arnova 10b G3 after having flashed our custom firmware version 0.4 or 0.41a (kasty-arn10bg3-40-04.zip or kasty-arn10bg3-40-041a.zip)
Thanks to J_Weidner, we now have a more recent dump that works on the newer tablets.
Here is an update (version 0.42) of our custom firmware with Google Play and root:
Kasty custom firmware download (version 0.42)
kasty-arn10bg3-40-042.zip
This firmware is specific to the Arnova 10b G3 capacitive screen model and should not be installed on other devices.
WE WILL NOT BE HELD RESPONSIBLE FOR ANY DAMAGE TO YOUR DEVICE.
THIS FIRMWARE UPDATE IS USED AT YOUR OWN RISK.
WE RECOMMEND TO FLASH THIS FIRMWARE ONLY IF YOU ARE ABLE TO RESCUE A BRICKED DEVICE USING ROCKCHIP FLASHING TOOLS.
Check our article for more details on this firmware and how to flash it: http://www.arctablet.com/blog/featured/arnova-10b-g3-custom-firmware-google-play-root-face-unlock/
Please don't flash the firmware if you already have installed a custom firmware and it's working fine.
This custom firmware is mainly for users that have a failing calibration on their Arnova 10b G3.
We'd like to hear the first users feedback on this custom firmware.
Mark
2012/07/05 - 14:39
Hello, I previously flashed my 10B G3 Capacitive Multitouch with your kasty-arn10bg3-40-041a firmware. My screen didn't rotate anymore like some other users on the forum described before. I just flashed my 10B G3 with the updated version 0.42 and the screen will rotate again. It seems everything works fine. Thanks J. Weidner and the crew for fixing this so fast. LaughKiss
Greets,
Mark
Ps, My device is an Arnova 10B G3 with a 10.1" Capacitive Multitouch Display (1024 x 600). The post for the kasty-arn10bg3-40-041a firmware update is for the Capacitive display. So i installed that one on my Multitouch device. Maybe this is what went wrong with the firmware update.
linh721990
Forum Posts: 23
2012/07/05 - 16:23
This works so good! Thanks admin and J. Weidner!
YAY, so happy my tablet works fine again (:
dwraith1
2012/07/05 - 18:15
Hi. Is there anything new in this update? I'm running 4.1a now with everything working ok bar some apps not working or installing and not being able to move apps to sd , so I'm not sure whether to bother with this update yet.
Cheers and keep up the good work!
pauloxy
2012/07/05 - 20:59
many thanks, mine is now completely working fantastic
Penpusher
2012/07/05 - 22:22
Works a treat! thank you Smile
Just want to add that it makes the Tablet much better, especially with Root access.
Have now installed AdAway which blocks the ads on some of the free apps.
Brilliant bit of work by you guys!!
J_Weidner
2012/07/06 - 16:50
Thanks to admin for this custom firmwareCool
Why doesnt funktion the App 2 SD applikation with my 8Gb micro SD card ?
J_Weidner
2012/07/06 - 20:47
J_Weidner
I'm not used to App2SD app, but it may not work because of the way the storage / sdcard is mounted.
This is maybe fixable, I'll add that to the list of things I need to check.
J_Weidner
2012/07/07 - 05:20
Thanks admin
J_Weidner
snakekiller
Forum Posts: 25
2012/07/07 - 14:56
hello i have my new 10b G3 tab tonight (belgium tablet)
is it save to use it. on these tablet.
her's the link of the store for tech spec.
http://www.vandenborre.be/tablet-pc/arnova-arnova-10b-g3-4gb
the screen is Capacitief multipoint
linh721990
Forum Posts: 23
2012/07/07 - 18:53
Is there a way to overclock you Arnova 10b G3?
And if so, do I need a custom kernel?
2012/07/07 - 19:17
Rockchip processors aren't known to be overclocking champions.
There's no way to overclock the cpu currently and a custom kernel would be hard to build anyway as Arnova hasn't published sources for their kernel.
2012/07/07 - 19:20
Knowing you have bought it recently in Belgium, can you check what the build number date is  in Settings / About ?
With recent firmwares (from month of May and later) our latest 0.42 firmware has been reported to work fine.
linh721990
Forum Posts: 23
2012/07/07 - 21:08
Hey
 Another question..
Which file do I have to edit to change the statusbar color? ;D
Lode
snakekiller
Forum Posts: 25
2012/07/08 - 00:44
hey i confirm now. and tested.
everythings works ok with this version .
many thx for reply.
Currently Online: mouhtar
62 Guest(s)
Devices in use: Desktop (56), Phone (7)
ESPADA
Fjustino
Lexibook333
honkomat
lex42
jmsp867
Topics: 6015
Members: 260827
