Bluetooth and GPS Dongle Support
Sengadog
Forum Posts: 33
2012/06/16 - 01:36
I have tried a GPS and Bluetooth dongle on my 10b g3 but they do not work, guess there are no drivers in the custome firmware, are adrivers/support going to be added? Would really like to use a GPS dongle to make use of Maps.
Thanks Received: 3169
2012/06/16 - 11:31
That's right, no driver for bluetooth dongle support on the Arnova G3.
fenice57 made a custom firmware for the Arnova 7 G2 with Bluetooth partial support, working only with BT dongles based on CSR chipset. When time permits, I'll have a look to see if it can work on the 10b G3.
Sengadog
Forum Posts: 33
2012/06/16 - 13:27
That would be great, thank you.  What about GPS dongle support, anyone had any luck with this ? I am loathed to get rid of my 10g3 for a tablet with built in gps.
Sengadog
Forum Posts: 33
2012/06/16 - 23:46
Just found a tempoarary solution to the GPS Location. I installed an app called FAKE GPS, I can then set the location using this. Then when I use an app that needs GPS to be enabled it thinks it is.
90 Guest(s)
Devices in use: Desktop (80), Phone (9), Tablet (1)
Djomla88
darkfly13
SONNY4669
borodachuk
h10101010
Vlad7Serg
Topics: 6011
Members: 260690
