Arnova10b g3 connecting to iPhone hotspot
chops660
2012/06/13 - 20:56
Is there a way to connect to the adhoc iPhone hotspot?
dlicence
Forum Posts: 15
2012/06/13 - 23:08
Android won't connect to adhoc networks by default. There are ways of doing it, but it involves rooting your device and modifying some settings.
chops660
2012/06/13 - 23:27
Is there a how to do it topic any where? Had a search and couldn't find much info.
I'm not very clued up on the android thing. But am quite impressed with my 10b g3.
Thanks Received: 3169
2012/06/13 - 23:43
First flashing this custom firmware will give you root access to the 10b G3, so you are able to modify system files.
Then, I think you need to edit the wpa_supplicant.conf with a dedicated application or a text editor.
I've never done that before, but that should give you some hints on what to search on Google Wink
chops660
2012/06/14 - 00:16
cheers, i did the firmware this morning, seems good, maybe just me but the battery also seems to have a longer life.
will have a search and see what comes up
thx
Thanks Received: 264
2012/06/14 - 00:39
if someone provides info about the wifi driver from the 10 g3, and the wifi suplicant i can try and modify one
2012/06/14 - 00:56
Here is /system/etc/wifi/wpa_supplicant.conf content:
update_config=1
ctrl_interface=wlan0
eapol_version=1
ap_scan=1
fast_reauth=1
There is some wlan related firmware in /system/etc/firmware, not sure of what you need as wifi driver.
2012/06/14 - 01:23
back up your wpa spulicant from system/bin
add this new suplicant http://www.mediafire.com/?fxzddsb2e6s54zq
set the permisions, and test it.
i asked about the drivers, because some suplicants are personalized.
chops660
2012/06/14 - 02:53
how do i get to root edit?
do i need root editing software to install the suplicant?
after firmware update, now after its plugged into pc, it shows as all files empty...?
i have tryed the root explorer and root browser apps but the wont open the file from post above?
sorry im not too techy, but keen to try.. thanks for any advice..
2012/06/14 - 13:13
Download this http://www.arctablet.com/users/forum/FileExpertLatest.apk
FILE EXPERT, this is the last free version that has root explorer and mounting options (in market these options are available now, only on the paid version )
Do not update this
then, activate from settings, root explorer, mount the system read and write
you do not need to open the file, you just need to copy it in system/bin and set the old permissions from the old wpa supplicant.
I REPEAT, IT IS NOT AN APP, JUST COPY IT IN SYSTEM/BIN AND SET PERMISSIONS
and test it
chops660
2012/06/14 - 23:22
Do not update this
and test it
Done this and still can't find hot spot? Should I be able to find it with a scan?
Or will I need to enterit maually?
When you say mount the system read ad write? Do you mean owner permison?
Thanks gordon
2012/06/15 - 00:11
well, if you did everything right, and the suplicand does not work, then you should google for other ics supplicants, and maybe you will find one that works, it is a trial and error thing, few devices with ics have the ad hoc available.
It is a option in file expert to mount the system as read only, or read and write, i told you to do this, because i don`t know what file system uses the 10b g3.
2012/06/15 - 00:18
The 10b G3 with our custom firmware is in ext3 fs, mounted writable in the boot, so the file copy thru File Expert should be no problem, provided you accept the SuperSU request to grant root access rights.
chops660
2012/06/15 - 11:50
Had a quick search last night, and the only thing I can see i might of done wrong was
Not turn the wifi off while copying in new wpa_suppliment
Will give it another bash tonight..
Coogie
Forum Posts: 14
2012/06/15 - 23:43
Hi _ is it possible to tether the iphone via a cable and get an internet connection? I tried but couldn't seem to get it to work?
95 Guest(s)
Devices in use: Desktop (89), Phone (6)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
