2013/01/21
Hello, bonjour,
Bad week for me, i have un arnova tablette 10bG3 with 2Go, i want more places to my applications, then i decided to put a new no-official firmware : kasty_oma-arn10bg3-41-046-2G.zip with Rockchip_Batch_Tool_v1.5.zip.
But, i can't find the recovery level with this &#x@ arnova tablette, reset/+, start/+, start/reset, start/usb/+, usb/+, alim/usb/+, alim/start/usb/+...arg !
Then i decided to make a bad thing, put the update.img on my tablette, i know... why why why... it's not a official firmware... use rockchip... but no connexion on rockchip with my 7 windows.
Then, it's big shit if i can say that (sorry by my french speeking)
Now, after some hours i find the combinaison to arrived at recovery level on my tablette, reset and after press start bouton and + bouton during 15 seconds... and the green guy arrived, but with bad face, and it's to late... i break Android apparamently.
Have you a solution to my situation, make un android boot version on a mini-SD ? a miracle-driver ? put all in a bin ? put off the battery ? less be a ass ?
I very in a big mess to write in english
Have a better week then me,
Rork
i want to believe but winter is coming !
2013/01/21
globula_neagra said
Can you still get the tablet in the flashing mode ?
1. with the reset i have "Arnova" white with background in black, 2 seconds in black and "Arnova" white with background in black
2. with the reset, start button and volume + button during 15 seconds, i have 0.5 second android icon, and after android icon with exclamation mark. After, i can't find a interactive mode. And, no reconnaize drivers with windows 7, or windows XP, or Ubuntu 10.4.
A protocole existing with the button to find flashing mode, different then n°2 ?
Finger cross...
a+
rork
try to use superoneclick to install the drivers when the device is not recognized when you see the android with the exclamation mark
if you succed, then use adb and issue the command
adb devices -> to check if the device is connected, if you get any king of result here is perfect
adb reboot bootloader -> this will reboot you tablet in flashing mode, where you are suposed to use rockchip tools to reflash the tablet, use restore, not upgrade
2013/01/21
globula_neagra said
Can you still get the tablet in the flashing mode ?try to use superoneclick to install the drivers when the device is not recognized when you see the android with the exclamation mark
Bonsoir, Hi,
No solution now, i have problem with superoneclick 2.3.3, it's not stable on windows 7, "no reponse" rapidely, one time, a driver is install and i have a message to reconnecting device, but nothing after. Put the tablette with green android and exclamation mark and connecting to the PC with superoneclick in life is sport ! No evolution on the tablette. On superoneclick i have two lines : killing ADB server and Starting ADB server daemon not running starting it now...
I have windows 7, windows XP, ubuntu 10-04 and ubuntu 12-04 if this can help something...thank you for your interest !
rork
install android sdk on one the ubuntu`s, add the udev rulles and run from there adb reboot bootloader
2013/01/21
i'm sorry, but it's to difficult for me. I have install android sdk on a ubuntu 10-04, a don't know if the udev rulles are good, must find it ? and install ? i don't find how do that (sorry), and after "run from there adb reboot bootloader"... ouhhhh ilt's totaly dark for me, i think it's a command in the terminal. If you can describe the chronologie more clarely, it will be better. Thank you for your time and patience,
rork
STEP 1 – CONFIGURE AND INSTALL UBUNTU 12.04 X64 ONLY !
- install ubuntu
-make all the updates
STEP 2 – INSTALLATION OF REQUIRED PACKAGES
a) Java JDK
sudo apt-get install openjdk-6-jdk sudo apt-get install openjdk-6-jre openjdk-6-jdk icedtea6-plugin b)Install Phyton sudo apt-get install python
c)Install GIT sudo apt-get install git-core
STEP 3 - INSTALLATION OF ANDROID SDK
- download from here http://dl.google.com/android/android-sdk_r20.0.3-linux.tgz
-the file must be downloaded in your Home folder/directory
-rename the file in android-sdk-linux.tgz
- run in terminal the command: tar -xvzf android-sdk-linux.tgz
You will notice a new folder created in the Home directory
We will now cd in the new folder: cd ~/android-sdk-linux/tools
./android (this command starts the android sdk manager)
Install any updates and packs that you need.
After you finish you will include the path environment of ANDROID SDK
-go to your home folder and press CTRL H (this will enable you to so the hidden files)
- open the file .bashrc file and add the fallowing at the end
# Android tools
export PATH=${PATH}:~/android-sdk-linux/tools
export PATH=${PATH}:~/android-sdk-linux/platform-tools
export PATH=${PATH}:~/bin
-open the .profile file and add at the end the fallowing PATH="$HOME/android-sdk-linux/tools:$HOME/android-sdk-linux/platform-tools:$PATH"
Installation of ANDROID SDK FINISHED
STEP 4 INSTALLATION OF FURTHER PACKAGES
-in terminal type sudo apt-get install git-core gnupg flex bison gperf build-essential
zip curl libc6-dev libncurses5-dev:i386 x11proto-core-dev
libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-glx:i386
libgl1-mesa-dev g++-multilib mingw32 openjdk-6-jdk tofrodos
python-markdown libxml2-utils xsltproc zlib1g-dev:i386
sudo ln -s /usr/lib/i386-linux-gnu/libX11.so.6 /usr/lib/i386-linux-gnu/libX11.so
STEP 5 CONFIGURE THE USB
-type in terminal
lsusb
glob@glob-M720-US3:~/WORKING_DIRECTORY$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 003: ID 046d:08ce Logitech, Inc. QuickCam Pro 5000
Bus 001 Device 004: ID 050d:935a Belkin Components F6D4050 N150 Enhanced Wireless Network Adapter v1000 [Ralink RT2870]
Bus 002 Device 002: ID 0e79:1455 Archos, Inc.
Bus 003 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
As you can see there is a line named Bus 002 Device 002: ID 0e79:1455 Archos, Inc.
Retain only the line 0e79 which is the vendor id.
gksudo gedit /etc/udev/rules.d/51-android.rules
a file will pop up and add this line
#Archos
SUBSYSTEM=="usb", ATTR{idVendor}=="0e79", MODE="0666"
Save and then:
sudo chmod a+r /etc/udev/rules.d/51-android.rules
Now go to the Home directory and press CTRL H and search for the folder .android, go there and open adb_usb.ini and add
0x0e79
Save the file
Restart the computer and check in terminal
glob@glob-M720-US3:~/WORKING_DIRECTORY$ adb devices
List of devices attached
0123456789ABCDEFÂ Â Â device
REQUEST FOR OTHER PEOPLE THAT ARE READING THIS GUIDE, DO NOT SHARE/COPY, REPOST THE GUIDE WITHOUT MY APROVAL
THX
admin, rork
I need to mention that this guide is for Archos devices, you need to adapt it, for your device
It is only for X64 ubuntu editions
2013/01/21
globula_neagra said
I do 3 steps, when i begin the step 4, in the terminal, i copy "sudo apt-get install git-core gnupg flex bison gperf build-essential", the terminal question the password, but i can't write it, no keyboard reaction and when i press enter "sorry, try again". i made a bad thing ? the terminal is apparamently active ?
Question : it's 5 requests for the terminal or one with space ?
thanks
rork
-in terminal typesudo apt-get install git-core gnupg flex bison gperf build-essential
python-markdown libxml2-utils xsltproc zlib1g-dev:i386sudo ln -s /usr/lib/i386-linux-gnu/libX11.so.6 /usr/lib/i386-linux-gnu/libX11.so
-type in terminal
lsusb
Bus 003 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for BluetoothAs you can see there is a line named Bus 002 Device 002: ID 0e79:1455 Archos, Inc.
#Archos
Save and then:
sudo chmod a+r /etc/udev/rules.d/51-android.rulesNow go to the Home directory and press CTRL H and search for the folder .android, go there and open adb_usb.ini and add
0x0e79
Save the file
Restart the computer and check in terminalglob@glob-M720-US3:~/WORKING_DIRECTORY$ adb devices
0123456789ABCDEFÂ Â Â deviceREQUEST FOR OTHER PEOPLE THAT ARE READING THIS GUIDE, DO NOT SHARE/COPY, REPOST THE GUIDE WITHOUT MY APROVAL
THX
enter the password that you use to log in on ubuntu
if you don`t have a password, put one
it does not appear on the screen when you enter the password
it is the normal terminal (black one), not the xterminal
2013/01/21
bizzarrly, the terminal run now, maybe a little sleep, i am in the step 4
a+
rork
2013/01/21
rork said
i see :
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 045e:076c Microsoft Corp.
Bus 001 Device 003: ID 0bb4:0001 High Tech Computer Corp.with arnova on device 3
2013/01/21
rork said
rork said
i see :
when i make the with arnova de green guy i have :
Bus 001 Device 010: ID 18d1:d001 Google Inc.
76 Guest(s)
Devices in use: Desktop (70), Phone (6)
