2014/06/12
The screen resolution on my Arnova 10b G3 is being reported as 1024 * 564 yet the spec sheet claims 1024 * 600.
I'd normally accept this, but the screen doesn't look to be running at a 1:1 ratio, it's quite fuzzy and just doesn't look right.
I'm running Cyanogenmod 7.
If there is a resolution to this issue i can't find it anywhere (Please excuse the bad pun)
The difference in the reported resolution may come from the status bar height that is not included in the calculation, I have seen that on many devices. It's quite likely to happen on the stock Arnova firmware, not only on your CM7 build.
As for the screen quality, the 10bG3 is a rather old model, using a rather cheap quality screen far from what we get with IPS displays nowadays. Or it may just be a density issue in your CM7, so you'd need to try a different density value. Please check our Arnova 10bG3 forum section, I think similar issue is covered in some posts regarding our custom firmware.
PS: I have moved your topic in the appropriate forum section.
mike2156 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
211 Guest(s)
Devices in use: Desktop (204), Phone (7)
