Topic RSS Related Topics
Arnova 10b g3 - move apps to sd card and internal storage
Topic Rating: 5Topic Rating: 5Topic Rating: 5Topic Rating: 5Topic Rating: 5 Topic Rating: 5 (1 votes)
2013/02/20
00:42
ok unit says 16 gigs available but when i go to install apps or anything it says insufficient storage available??any ideas on how to fix??
2013/02/28
21:46
Arras
Arnova 10b G3 Dual Touch
47
When i install these files (mcsgeek post) i have a nand flash with 0 B (it should be the ext sd card with 8 GB) and a sd card with 567 MB (the same space the nand flash was before the system modification) the external sd card seems to be not recognized (for information my anvova 10b g3 is a 4 GB and i have install the 4.1 with more space for apps of this site and the sd is a sandisk 8 GB classe 4)
I post here the VOLD.fstab (i have write in red the differences between my file and the line in the post in blue)
## Vold 2.0 Generic fstab
## – San Mehat (san@android.com)
## Regular device mount
## Format: dev_mount <label> <mount_point> <part> <sysfs_path1…>
## label        – Label for the volume
## mount_point  – Where the volume will be mounted
## part         – Partition # (1 based), or 'auto' for first usable partition.
## <sysfs_path> – List of sysfs paths to source devices
## Example of a standard sdcard mount for the emulator / Dream
# Mounts the first usable partition of the specified device
#dev_mount sdcard /mnt/sdcard auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
dev_mount flash /mnt/sdcard auto /devices/virtual/mtd/mtd9/mtdblock9
dev_mount sdcard /mnt/external_sd auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0
dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_host/usb
## Example of a dual card setup
# dev_mount left_sdcard  /sdcard1  auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
# dev_mount right_sdcard /sdcard2  auto /devices/platform/goldfish_mmc.1 /devices/platform/msm_sdcc.3/mmc_host/mmc1
## Example of specifying a specific partition for mounts
# dev_mount sdcard /sdcard 2 /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
here the line of mcsgeek
# dev_mount sdcard /data/external_sd auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0
dev_mount udisk /mnt/usb_storage auto /devices/platform/?usb20_host/usb
dev_mount user /mnt/external_sd auto /devices/virtual/mtd/mtd9
Do you know what is the probleme with my file. Must i "rename" sdcard to flash, must i insert the "?" or the "/mtdblock9". I am careful because when i first test i "bricked" my tablet and i reinstall everything.
Thank a lot for all these solution and your answer.
2013/03/27
10:36
Arras
48
I have found the solution to swap ext sd to internal sd.
I have tried whith mcsgeek solution but it doesn't work (on my tablette), but i have find another vold.fstab on
[[** please register to see this link **]] .
i download this file: [[** please register to see this link **]]and i copy the VOLD.FSTAB which is in the zip in root/system/etc/. I restart and it's work.
When i tried whith mcsgeek solution, i installed the file "install-recovery.sh" in the same place (root/system/etc) and i haven't delet it so i don't know if it's work without it. I will test later.
Thanks admin,mcsgeek, oma, and everyone who have permit to increase performance of my tablette.
2013/04/05
12:53
Arnova 10b G3 capacitive
49
Hi I have tried to download the kasty f ile but it came as arctablet.php and not supported ! I have done the google play succeessfully last year. Sorry "download.php
2013/04/07
10:38
Arras
50
I don't understand your question, if it's a question
2013/04/08
13:12
51
Having read it again it does sound  a bit odd! I was in a rush and the keyboard was slow, it is now. I had downloaded the "kasty" file and "rockchip"  to my tablet but in the download file they were named "download.php" and when I tried to open them it showed "file not supported". So my post. However, later I "renamed" them with the correct names and were then OK.. Only then did I realise that I should have downloaded them to a separate computer, this was not immediately clear. I don't have another computer at the moment but when I do I'll give it another try. Hope this makes more sense.Sorry for the confusion. Cheers!
admin: 3668
globula_neagra: 1873
Guest Posters: 36
Members: 74102
Forums: 122
Topics: 2798
Moderators: HaroldG (117), globula_neagra (1873), exelletor (344)
Administrators: admin (3668)
