[ ROM ] Arnova 10b G3 ICS custom firmware (version 0.42) with Google Play, root and Face Unlock
Thanks Received: 3177
2012/06/13 - 17:26
sneds16 said
This is driving me demented! i have tried the process numerous times and with 2 different micro usb  cables but when it comes to pushing the vol + button and the reset it gives a windows error noise and says it does not recognise the usb device and does not work.......what am i doing wrong i have watched the video and followed the instructions and also the written instructions, my device is a arnova 10b G3 UK model and i am running windows 7, also i tried it on my laptop as well as my desktop  YellYellYellYell PS it goes into recovery mode no problem without the usb attached cant understand as i have tried 2 new usb micro's
Can you see the tablet or an unknow device in Windows device manager ?
Also have you tried to turn off automatic drivers installation on Windows ? (see troubleshooting section here: http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/)
chops660
2012/06/13 - 17:33
any ideas anyone?
15:46:15 992 Rockchip Batch Tool v1.4.0.0 start run 15:59:08 546 Rockchip Batch Tool v1.4.0.0 start run 16:15:33 128 <Layer 5-4> Test Device Start 16:15:33 134 <Layer 5-4> Test Device Success 16:15:33 141 <Layer 5-4> Check Chip Start 16:15:33 147 <Layer 5-4> Check Chip Success 16:15:33 152 <Layer 5-4> Get FlashInfo Start 16:15:33 166 <LAYER 5-4> INFO:FlashInfo: 0 0 80 0 0 8 10 18 32 0 1 16:15:33 170 <Layer 5-4> Get FlashInfo Success 16:15:33 175 <Layer 5-4> Prepare IDB Start 16:15:33 177 <LAYER 5-4> INFO:CS(1)  (4096MB)  (SAMSUNG) 16:15:33 221 <Layer 5-4> Prepare IDB Success 16:15:33 227 <Layer 5-4> Download IDB Start 16:15:33 660 <Layer 5-4> Download IDB Success 16:15:33 665 <Layer 5-4> Reset Device Start 16:15:34 669 <Layer 5-4> Reset Device Success 16:15:34 674 <Layer 5-4> Wait For Loader Start 16:15:37 811 <Layer 5-4> Wait For Loader Success 16:15:37 882 <Layer 5-4> Test Device Start 16:15:37 889 <Layer 5-4> Test Device Success 16:15:37 894 <Layer 5-4> Download Firmware Start 16:18:58 406 <LAYER 5-4> ERROR:RKA_File_Check-->RKU_ReadLBA failed,Read(284190415),RetCode(-4) 16:18:58 419 <LAYER 5-4> ERROR:DownloadImage-->RKA_File_Check failed(system) 16:18:58 426 <Layer 5-4> Download Firmware Fail 16:21:43 241 <Layer 5-4> Test Device Start 16:21:56 255 <LAYER 5-4> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-4) 16:22:10 291 <LAYER 5-4> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-4) 16:23:16 709 Rockchip Batch Tool v1.4.0.0 start run 16:23:30 559 <Layer 5-4> Test Device Start 16:23:45 563 <LAYER 5-4> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-4) 16:24:01 565 <LAYER 5-4> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-4) 16:24:17 568 <LAYER 5-4> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-4) 16:24:18 573 <Layer 5-4> Test Device Fail 16:25:24 254 <Layer 5-4> Test Device Start 16:25:39 258 <LAYER 5-4> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-4) 16:25:55 261 <LAYER 5-4> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-4) 16:26:11 264 <LAYER 5-4> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-4) 16:26:12 268 <Layer 5-4> Test Device Fail
chops660
2012/06/13 - 17:37
sneds16 said
sneds16 said
exelletor said
Do not switch your unit off before putting it in recovery mode (=pressing the reset+volume buttons)
thanks, but i have also tried that and when i release the recovery button then all i get is a double dunk error noise and nothing happens.
the instructions for installing google play states to make sure tablet is off, very confusing but i hav tried both ways without success Frown
It's best to start with the tablet off, but enabling flashing mode with Reset and Vol+ should also work from a running tablet.
You'll know you've entered it if the tablet screen is off, it should not display Arnova logo or anything else. Have you checked the (second) video in the Blog article ?
go into devices and printers, right ckick unknown device, update driver with one you have d/loaded from rock chip... gl
sneds16
Forum Posts: 13
2012/06/13 - 17:39
when i dont try to go into recovery it shows in devices then when i go for recovery and vol+ i disappears and sits blanc screen till i click reset only to recover it. i am now trying the trouble shoot method, thanks for all the help Laugh
chops660
2012/06/13 - 17:43
chops660 said
any ideas anyone?
now left with arnova 10b g3 stuck in recovery mode
chops660
2012/06/13 - 17:58
I got error msg saying failed, and stuck in recovery mode...
pressed the reset button again and tablet went through new set up, and hey presto its done has ggogle play etc...
sneds16
Forum Posts: 13
2012/06/13 - 18:21
looked but the driver update from rock chip is a iso file and it does not recognise that file as a updateFrown
sneds16
Forum Posts: 13
2012/06/13 - 18:29
i give up! i tried but did not work mate. also tried going into printers and devices and looking for unknown device and updating the driver through that as sugested by chopps660 in chat #22 but as the update is a iso it is not recognised, do you ever feel it is just not ure day lol Cry
Gouranga
Liverpool, England
Forum Posts: 20
2012/06/13 - 18:56
Have you downloaded the correct rockchip thingy for your device?  Mine is an .inf file, which worked when I was finally able to do the reset thingy properly.  Then, even though the tablet was blank, windows picked it up as a new device and I was able to go to the correct folder and the .inf file that was in the 'drivers [xp]' folder worked.  As soon as that happened the Rochchip thingy recognised my tablet and, following the instructions on the video, I was able to upgrade!  As I said before: if a 65 year old great granny can do it - anybody can!  Good luck and don't give up.  Leave it a few hours or overnight and try again.Smile
Smdh
2012/06/13 - 22:07
Thanks to Excellator for the instructions on driver install.  I really am a techno biff but am now the proud owner of a Play Store app on my 10b G3 (in the UK).  So truely anyone can do it.  Patience is the key.  Some experiences I had I would like to share;
In preparation I noted the build standard so I had the correct driver in mind Win 7 32Bit.
Placed the update from the Kasty file on the desktop.
Chose the correct size pin for the reset hole (you can feel a rocker depress whilst entering recovery/flashing mode).
Changed the device installation settings as descibed in the trouble shooting section of the Rockchip Flasher Tool.
Followed the instructions, but every time I tried to enter recovery with the tablet off it started coming on.  Therefore as others had done I tried it whilst on, saw the volume go up as the + vol key was depressed then inserted the pin and low and behold the screen went blank after several seconds.  At the same time saw a pop up on screen that told me a USB device wasn't recognised.  Went into device manager and found an unrecognised device but this wasn't under the USB's but elsewhere highlighted with a little yellow triangle then proceeded to load the driver .  Didn't work the first time as I had unloaded the driver to my desktop but the drver search only went as far down as folders not files.  Placed the driver back inside the folder and tried again and asked it to load from the driver folder; lo and behold it started loading.
After a little jig of appreciation (was this premature?) I continued to follow the instructions.  Download started and finished minutes later, tablet sparked into life and having gone through all the custom set up on the Arnova there it was the "Grail" - Play Store.  Downloaded the Mrs's fave TV app and the whole expense of the purchase was justified as I had promised her.
Apologies if this was simplistic but that's me.  But if I could say thanks to (if you can use this term in a friendly way) the geeks out there who developed this firmware update.
With regard to Gouranga well theres over 110 years between us.  A challenge to you young uns if ever I saw one Wink.
Sengadog
Forum Posts: 33
2012/06/13 - 22:14
My Story, firstly I was having problems getting tablet in recovery mode when usb cable was inserted. Instead of following instructions I pressed VOL + then insirted paper clip into reset hole, held both for a couple of seconds then removed paper clip first followed bu VOL + this then put Arnova into recovery.
Other problem I had was trying to install driver, this failed evry time. So, I disabled USB debugging on tablet  then re plugged in Arnova and let windows install Arnova drivers. Once complete, I did the reset procedure above and everything worked as described. I now have the new firmware installed.
BTW im on Windows Vista.
2012/06/13 - 22:43
I'm glad that most of you got it working and a bit sorry if the instructions are not that clear as they should be.
If you want to contribute a complete firmware flashing guide for the other users, you are welcome to use our WIKI where I have created a page for the firmware flashing purpose : http://www.arctablet.com/wiki/index.php/Installing_a_custom_firmware_on_Arnova_G2_Arnova_G3_tablets
You can edit it by going to this page and using the log in button in the top right corner then using the same username and password you have on this forum.
mikey2Dworld
2012/06/14 - 08:10
Super! works great, now waiting for C.F. for the arnova 7b g3
craigm10
2012/06/14 - 13:59
Hi, To all those struggling to get into recovery mode, I had the same problem. What I did was connect the tablet to the computer and let it install the driver. I then went to 'devices and printers' and uninstalled the driver. To get the tablet into recovery mode, leave it on, press vol+ for a couple of seconds, whilst vol+ is pressed, insert paperclip into reset hole. Hold it there for more than 15 seconds. Remove the paperclip, but still keep hold of vol+. Let it go after a couple of seconds.
I kept on letting go of both at the same time, which just caused the tablet to reset.
It now works in all of its rooted glory. Nice to have the play store as well. It even seems to run smoother. Before it wouldn't play iplayer or netflix, now neither are an issue. Laugh
Hope this helps.
densys
2012/06/14 - 18:43
Am I also going crazy, spent until 1:30 in the morning and all early thismorning trying to get all this to work with my 8b G3.
Cannot get the thing into flashing mode, pushing + and reset seems to just simply reset the machine no matter how long I hold them in.
An "unknown device" showing in device manager on both windows 7 32/64 bit (I have tried two machines) - but this device disappears as soon as I release the reset button.
I have tried, one handedly, to install the usb driver from the rockchip folders - windows just keeps saying that the driver installed is the best option, even though it's unknown.
Maybe I have assumed that the 10b 3G would have the same hardware, just a bigger screen.
I have had other tablets and have never had a problem installing stuff like this - I tend to try many angles and always get there - this one has beaten me!
Some advice would be amazing....
Chris
199 Guest(s)
Devices in use: Desktop (183), Phone (16)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
