[ ROM ] Arnova 10b G3 ICS custom firmware (version 0.42) with Google Play, root and Face Unlock
2012/06/12 - 19:40
The Arnova 10b G3 tablet is a product refresh of the Arnova 10b G2 best seller, updated with latest Android 4.03 Ice Cream Sandwich and 1 Gb of RAM. The lack of Google Play (formerly Android Market) support is one the biggest inconvenience on the device, we are happy to bring you a solution. Here is a custom firmware to add Google Play/Android Market, Google Face Unlock support, full root with write access to /system.
Image Enlarger
We have published an Android 4.1 Jelly Bean firmware update for the Arnova 10b G3,
don't forget to check it !
This firmware is for the Arnova 10b G3 capacitive screen model only, don't flash it if you have a resistive (DT or Dual Touch) model. The compatibility issues have been resolved with the latest firmware dump (thanks J_Weidner) and the custom firmware is reported to work on all old and new Arnova 10b G3 capacitive models.
Arnova 10b G3 custom firmware features
  • Clean installation of latest Google Play Store 3.5.15, no more missing apps (Twitter, Facebook...)
  • Full root support with writable /system partition
  • Root access is controled thru SuperSU.apk v0.89 (free version), a cool upgrade to SuperUser.apk by XDA developer Chainfire
  • Updated Rockchip loader to latest version (2.20)
  • Added Face Unlock feature from XDA dev
  • Face unlock works reasonnably well considering the relatively low camera resolution (0.3 Mpix)
    Quick demo of the Face Unlock feature on an Arnova 9 G2 running a custom ICS firmware.
    Our custom firmware can be installed in two ways. The first method is the easiest and will let you have Google Play running in about 10 minutes. The second method erases all the data stored on the tablet, but uses a safer approach.
    Arnova 10b G3 custom firmware install easy procedure
    Please note that this flashing method is easy to run but includes the same risks as a regular firmware flash. If it goes wrong…
    darkwave83
    2012/06/12 - 22:18
    Thanks for the firmware. Works brilliantly cheers Laugh
    Eysinem
    2012/06/12 - 22:47
    Thanks very much. Now I can play with my tablet ūüôā
    sneds16
    Forum Posts: 13
    2012/06/12 - 23:37
    followed the instructions to the T and will not work i am in the UK, and i have tried 3 times now and it will not workYell
    when i switch my 10b g3 off and hit the reset button while holding volume+ my pc does not recognise the usb but when i hit reset with out hitting vol+ my pc notices the usb....wtf also without the usb in the reset and vol+ chucks it into the recovery mode, just with the usb it does not work damn damn Cry
    exelletor
    Blog Team
    Forum Posts: 450
    Thanks Received: 30
    2012/06/12 - 23:50
    Do not switch your unit off before putting it in recovery mode (=pressing the reset+volume buttons)
    Smdh
    2012/06/12 - 23:55
    My PC recognises the Tablet as a USB but when I go to the driver and try to install by double clicking it says it cannot be opened and must be associated with another programme. Can someone advise me on where I go from here?  What do I do with the Driver?
    I am running Windows 7 premium 32 Bit and have turned off auto driver updates as stated in the instructions.
    sneds16
    Forum Posts: 13
    2012/06/13 - 00:09
    thanks, but i have also tried that and when i release the recovery button then all i get is a double dunk error noise and nothing happens.
    the instructions for installing google play states to make sure tablet is off, very confusing but i hav tried both ways without success Frown
    exelletor
    Blog Team
    Forum Posts: 450
    Thanks Received: 30
    2012/06/13 - 00:09
    How do you mean, install it by double clicking and needing another programme? What you need to do, is to first put your device in recovery mode. Then go to your device manager, you should see an unknown device, right click on it and click on update usb driver(or whatever, my windows is not in English); select search for drivers on the pc and navigate to the directory with the appropiate driver (no double clicking on the driver itself, just click ok when you found the directory)
    exelletor
    Blog Team
    Forum Posts: 450
    Thanks Received: 30
    2012/06/13 - 00:13
    Hmm... Noticed you said the following:
    All I can advise is to try again with doing exactly the same and may be even trying another usb cable. Or wait for admin to help you out with possible different solutions. ūüėõ
    mgsdude
    Forum Posts: 14
    2012/06/13 - 09:56
    For the life of me I cannot get into recovery :/
    Gouranga
    Liverpool, England
    Forum Posts: 20
    2012/06/13 - 11:34
    Hi folks
    It took me ages and I ended up doing it via my laptop as the PC kept on recognising the tablet and installing a driver for it.  Someone above saved my bacon by advising that, sometimes when you stick your pin in the little hole, it doesn't actually switch anything on or off.  He advised checking that when you press you actually feel a switch being switched.  That's what I did in the end.
    Many thanks to the developer as I have loads of apps in Google Market (now Play), and would have been very upset not being able to use them.
    Now then, I am a 65 year old female pensioner, if I can do it anyone can!  Keep trying.Wink
    2012/06/13 - 13:13
    It's best to start with the tablet off, but enabling flashing mode with Reset and Vol+ should also work from a running tablet.
    You'll know you've entered it if the tablet screen is off, it should not display Arnova logo or anything else. Have you checked the (second) video in the Blog article ?
    2012/06/13 - 13:18
    Gouranga said
    Hi folks
    Glad to hear you finally got it working.
    This custom firmware isn't really development, Google made the hardware work producing Play / Android Market and great apps, we've just been making them fit in the vendor firmware that wasn't made for it.
    Everybody should be able to run the flashing procedure, we've tried make it clear as possible, but it's always good to have feedback if things should be explained differently...
    Have fun with your tablet Wink
    Gouranga
    Liverpool, England
    Forum Posts: 20
    2012/06/13 - 13:42
    Thank you.
    Good luck to all who are trying.  Follow the instructions for your particular model from: http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/  and that will get you flashed, then refer to the video at the top of this page for installing the new stuff.  Smile
    sneds16
    Forum Posts: 13
    2012/06/13 - 17:20
    This is driving me demented! i have tried the process numerous times and with 2 different micro usb  cables but when it comes to pushing the vol + button and the reset it gives a windows error noise and says it does not recognise the usb device and does not work.......what am i doing wrong i have watched the video and followed the instructions and also the written instructions, my device is a arnova 10b G3 UK model and i am running windows 7, also i tried it on my laptop as well as my desktop  YellYellYellYell PS it goes into recovery mode no problem without the usb attached cant understand as i have tried 2 new usb micro's
    Currently Online: vishu bhatnagar
    55 Guest(s)
    Devices in use: Desktop (54), Phone (2)
    vishu bhatnagar
    djwood1014
    4ipolino
    thomashansmuller11
    abro
    Yoyoo
