Arnova 10b G3 custom firmware with Google Play, easy flashing method
Thanks Received: 3169
2012/06/22 - 09:59
Our custom firmware provides Google Play (Android Market) access on the Arnova 10b G3. It seems there have been a few users who haven't been able to install this custom firmware so I've made an easier way of flashing it. This is valid only for the Arnova 10b G3 capacitive model, don't try it on a resistive Dual Touch (DT) model.
Please note that this flashing method is easy to run but includes the same risks as a regular firmware flash. If it goes wrong for some reason and bricks your tablet, the only way to recover it (if the hardware isn't damaged) will be to use Rockchip Flashing tool. In this situation, for those who couldn't get the flashing tool to work, they may get stuck in restoring their tablet.
  • Step 1. You need to download and install Arctools from Appslib.
If you don't have Appslib installed, you'll need to download it from here: http://appslib.com/download/index.html
When in Appslib, search for "Arctools", download and install the application.
  • Step 2. Within Arctools, go to Firmware tab, select the custom firmware to flash from the listbox (latest is currently version 0.41a) please read and understand the warnings and click the checkbox if you agree, then click the Download button. The file download and unpacking should take a few minutes to complete depending on your Internet connection speed. When it's done, you'll be invited to restart your tablet.
  • Step 3. After rebooting the tablet, a "Firmware updating" dialog will ask for confirmation to install the package (=flash the firmware) click Install button. The tablet will reboot and install the firmware.
  • Step 4. After a few minutes, your tablet will be updated with the custom firmware. Setup your Account on Google Play Store and enjoy !
The following video goes thru all the procedure steps on an Arnova 7f G3, it works the same on the 10b G3.
iww
2012/06/22 - 16:59
Afternoon,
I was one of the many, unable to get my Tablet into flashing mode, so I was eagerly awaiting this new method. All progressed well, and was the same as the video exactly.
After the installation was complete, I was concerned that all of my existing apps and bookmarks were still on the home screen, but when I went to the apps section the new Play app was there, however when I tried it, the window opened for a short while, with no option to sign in, and then went back to the apps screen.
As the play app was added to my Tablet, I feel the firmware was successfully. I wonder as my Tablet is less than a week old, might it not be fully compatible with this upgrade.
Please advise.
10b G3
4.0.3
Kernal version 3.0.8+
Regards
Ian
BBDL
Forum Posts: 17
2012/06/22 - 23:05
Can this method be used even if you can flash with the rockchip tool???
I was thinking that if/when there are new fimwares available, it seems a much simper method of flashing. Cool
lmg670
2012/06/23 - 14:57
Thank you so much for this!!!! I am a complete 'puter biff and was getting frustrated beyond belief trying to 'flash' my tablet..... this does it all without the worry/hassle!! thanks a million x
Sengadog
Forum Posts: 33
2012/06/23 - 20:57
Very Odd, I can flash the new firmware using the original flashing method time and time again, but the verion via arctools fails, it downloads and unpacks, but following reboot it says failed. Tried this three times with the same result. So resulted in using rockchip method again instead.
s_dixon9@sky.com
2012/06/24 - 10:08
Only bought my arnova 10b G3 on Friday and was so upset and disappointed.  The Applib was a waste of time.   I was unable to download books and read them from any of the bookstore apps.  I followed your instructions and fantastic it worked.   I am now using Google play etc and it's wonderful.  Doing everything I bought it for.  It was so easy to follow and I am not clued up at all.  Thanks once again . Kiss
BBDL
Forum Posts: 17
2012/06/24 - 16:18
I've just flashed my tab with the arctools tool, everything went ok. I'm not sure why but all my aps were still there ( I was expecting to have to install them again). Still can't get I player to work properly though .......... buffering all the time and running miles out of sinc. Oh well can't win them all.
Coogie
Forum Posts: 14
2012/06/24 - 18:07
I finally upgraded using this easy method, and it worked, but not without some issues
After the first install, the screen would not respond, so I could not select 'Yes' on the final prompt. I had to restart the tablet to get it to respond, and was faced with an 'install did not complete' prompt. Google Play was there, but I got an error message if I tried to download any apps.
I tried the set up again, but it only got about half way before I got a failed message.
About to give up, I just restarted the tablet and to my surprise all is working including Google Play 🙂
I'm not convinced it installed completely correctly, or what I did, but hey, it's working, so I'm happy 🙂
Coogie
Forum Posts: 14
2012/06/24 - 18:16
Forgot to add - so far I have been faced with 2 apps that will not install.
I get a "Couldnt install on USB storage or SD card" message. Is this because the apps are not made for tablets or there is insufficent space on the internal storage? The app is 18MB and I apparently have 148MB available, so I dont understand?
iww
2012/06/28 - 21:02
Success at last,
I used both the flashing method, then this easier method, and also copying and pasting, all had the same result, the Play icon was there but it would only try to open briefly, then close straight away. I got the feeling that the tablet was getting very sluggish, and unresponsive.
As I had found another method to get apps from Play (next post). I reluctantly admitted defeat, and decided to go through the tablets settings to the full reset option to get back to where I was before these attempts to upgrade.
After backing up my purchased apps, and following the on screen prompts. The tablet started right from the beginning again, language, time zone, installing the bundled apps, etc.
At this point gmail, Play were both working perfectly.
I now have a relatively cheap tablet, but with the full access to the vast array of quality apps.
Thanks to all concerned
Ian
iww
2012/06/28 - 21:15
Market apps without Play Store.
Nothing clever about this, as I thought of trying it myself, it must be obvious to many.
As I had an android phone with access to the Play Store, I thought I would try backing up one of my apps to my sd card with a file manager, once the .apk file was on the sd card, I could upload it with Dropbox. Once Dropbox is on your tablet, all apps handled this way will install straight from Dropbox.
Dropbox can be installed on your tablet from AppsLib, and AppsLib will never be used again
Ian
The following users say thank you to iww for this useful post:
Rozza
linh721990
Forum Posts: 23
2012/07/01 - 11:21
Would this work on a Archos Arnova 10 G3 Capacitive Multitouch?
Just want to be sure I don’t brick my phone.
And how can I be sure to check if it is compatible, any way to check?
Can you see it by the model number? My modelnumber is AN10BG3
Thanks,
Lode
twiddle
2012/07/04 - 22:15
Hi tottally new to all this. tried the firmware thing didnt work! easiest way i found to get  apps on the tablet ,was to down load them to my pc as .apk files and manually install them real easy
twiddle
2012/07/04 - 23:28
HERE TO HELPCool
agster95
2012/07/05 - 11:31
I've been trying this for a while and flashing doesnt work either. i went to firmware, choose the right firmware, agreed, pressed download but when i do i get a notification saying Error95:Firmware file copy failed-Archive file cannot be accessed, please check that your device is not mounted on usb. it is not. and i tried it being mounted nothing happened and ive reseted the tablet twice and still wont work. help?
118 Guest(s)
Devices in use: Desktop (110), Phone (8)
sanja2806
aliveli4950
WobilGZ
vhtnow
froidhiver2
froidhiver
Members: 262111
