Arnova 10b G3 battery life
arc64
2012/06/15 - 20:04
Hello everybody,
I have recently acquired an Arnova 10b G3 which works pretty well so far, I'm just disappointed by the battery life.
Starting from a fully charged battery, I've watched like 2 movies (total around 3 hours) before the battery got empty. Is my device defective, what is your tablet battery life ?
Thanks for your help
dlicence
Forum Posts: 15
2012/06/16 - 17:56
No that sounds about right. You're not buying a top-end tablet here so there are trade-offs, and battery life is one of them. Playing games take even more resources so I've had less than three hours out of it while firing birds at pigs 🙂
Sengadog
Forum Posts: 33
2012/06/16 - 18:46
As this is a new machine, with all rechargeable batteries it will take a few full discharge and charge cycles before the best performance is seen. Always try to run battery down fully then recharge fully, performance should get a bit better.
Thanks Received: 264
2012/06/16 - 19:01
it also depends on what are you using the tablet to do, if you watched 2 hd movies it is a ok lifetime for the battery.
dlicence
Forum Posts: 15
2012/06/16 - 19:31
This is actually not entirely true now - modern batteries do not like to be run all the way down and recharged fully each time.
It is correct though that it could take a few days on and off charge before the battery reaches it's full potential
91 Guest(s)
Devices in use: Desktop (85), Phone (6)
asgard2701
Rob_nl
shadowlabs
grot
techrey
mickey2669
Topics: 6028
Members: 261271
