Arnova 10b G3 Android 4.1 Jelly Bean (test firmware)
Thanks Received: 3177
2012/10/02 - 10:52
Here is a test firmware based on neomode's NeoCM10 Leon, thanks to him.
 Image Enlarger
I have made a few modifications on neomode's firmware:
- switched default language to English
- put back original model info in build.prop
- made /system writable
- made more space to install application (1.5 Gb)
- removed CWM recovery
- removed some (unecessary) apps, they all can be found on Google Play Store anyway.
Firmware download:
kasty-arn10bg3-41-042c-1_5G.zip (updated 2012/10/04)
This firmware is specific to the Arnova 10b G3 and should not be installed on other devices.
WE WILL NOT BE HELD RESPONSIBLE FOR ANY DAMAGE TO YOUR DEVICE.
THIS FIRMWARE UPDATE IS USED AT YOUR OWN RISK.
WE RECOMMEND TO FLASH THIS FIRMWARE ONLY IF YOU ARE ABLE TO RESCUE A BRICKED DEVICE USING ROCKCHIP FLASHING TOOLS.
Flash with Rockchip Batch Tool, use Restore button not Upgrade.
After first boot, the touchscreen may not work, you will need to restart your tablet (keep power button pushed, or use a paperclip in the reset pinhole).
Known issues:
- camera image reversed when capturing.
- some lag in the user interface / touchscreen
I am releasing this firmware as a proof of concept so you can try it and report problems.
I can't make sure this will lead to a fully working firmware nor I will have time or will be able to correct all the issues.
Also I am relying on the community so you guys can help each other with flashing documentation and support.
caballon, Sylvania
8Bitrabbitech
Forum Posts: 19
2012/10/02 - 19:29
Thank you very much Sir, try it right away and report if there are issues.
1.Batterie status not Working
2.not chargeing
3.camera and orientation solved with set orientation play store
4. New resolution is great performance is gold
5.storage calculation Full 8gb with nand and flash
2012/10/03 - 00:48
Thank you for your report 8Bitrabbitech, as well as Stellar7 for his report in PM Wink
The accelerometer problem is fixed, thanks to Exelletor, the battery status is still broken.
I'll look what I can do for these issues and will provide a new test firmware update soon.
2012/10/04 - 21:00
I have done a small update on this test firmware: the accelerometer should be fixed now (thanks exelletor !) and the the default Arnova 10b G3 File explorer application is added. The battery charge indicator still gives wrong info while the tablet is running, it just seems to pickup the right value on boot.
See first post for the file update.
2012/10/07 - 00:14
I'm working on a firmware update for the Arnova 10b G3 to be published soon.
Latest version now runs on ext4 for system, data and cache partitions, it is quite stable and the user interface run way faster than previous builds. I've done a quick bench with Antutu, it gives an idea of the performance.
Image Enlarger
Oma7144, 8Bitrabbitech, CroCop
sms24
2013/01/06 - 21:10
and is ther a link for the new firmware with the problems fixed?
Tyvm
JEssicannn
Forum Posts: 252
2019/10/23 - 01:28
52 Guest(s)
Devices in use: Desktop (44), Phone (8)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
