2012/12/31
I was bored the other day and came across http://crewrktablets.arctablet.com/, i saw there was a release of 4.2.2 on the Odys Loox . I noticed it ran on RK2918 hence this thread, if any chance can this be ported over to the Arnova 10B G3 ? ( You can remove that link if you want to keep it secret :3 i was just being curious)
There's nothing secret about http://crewrktablets.arctablet.com/Â , the guys from this crew are doing an excellent work and we're very happy to help them with what we can.
I think that Android 4.2.2 JellyBean usually requires a kernel newer than version 3.0.8 that we currently have for the Arnova 10bG3. As the 3.0.8 kernel sources for the 10b G3 are available it's maybe possible to make an update, but that requires some work, which I am not very familiar with and I currently focus on newer models (based on RK3066, RK3188 and other platforms).
Hopefully someone else from the dev. communities may wish to help.
2012/10/05
I have tested yesterday "CrewRKTablets_RK29_Loox_AOSP_4.2.2_20130222" and replace kernel by "kernel_308_10bg3_arnova", not the dt one (but i think my tablet is a dt but whith this kernel it doesn't start)
install fix :
"CrewRKTablets_AOSP_4.2.2_120_DPI_Fix",
"CrewRKTablets_AOSP_4.2.2_Format_NAND_Fix",
and try without "CrewRKTablets_AOSP_4.2.2_Sensor_90_Degree_Fix". the screen can only be hold verticaly.
and i install "CrewRKTablets_AOSP_4.2.2_Sensor_90_Degree_Fix", but the rotation work upside down, it is no usefull. I don't know if it can be invert.
But it seem to be imposiible to move app to SD.
I tried to do it with the fix of oma (extsd to nand, i have tried either ext to nand otg) but it doesn't work) I will try again later.
It would be nice if oma or someone success to repair the rotation bug (I am only an user, not a programmer).
If you try this rom you will have another experience of this tablet (arnova 10b g3)
This Rom is exellent, every thing else work fine (as JB 4.1 with pip and more space 2GO).
Thank OMA and thanks arctablet you are doing very good job
89 Guest(s)
Devices in use: Desktop (83), Phone (6)
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
ilval
