Where to find custom firmware
b_kennedy
2012/03/11 - 10:39
Hi guys. Just bought the 10b version for my daughter. I read that with a custom rom from archtools it is supposed to make it much improved. I've had a little browse but could only find one for the 10 and not 10b. Has anyone got a link and with possible instructions. Any other advice such as 'definately don't do this' etc will be much appreciated.
If it does brick can I still recover with standard rom?
Thanks in advance
Thanks Received: 3169
2012/03/11 - 10:42
Can you specify if it's a capacitive or resistive (Dual Touch) model ?
b_kennedy
2012/03/11 - 11:54
From what I've read I think the 10b is capacitive but I'm probably wrong. I'm collecting the item this afternoon so won't know until then unfortunately. Will it say in the settings?
2012/03/11 - 12:43
If it's like on the 7BG2 DT, the resistive should say DT on Dual Touch on the box and tablet case.
You'll feel it's resistive if you need to apply some pressure on the screen for it to get your touch input, else it's probably capacitive.
b_kennedy
2012/03/11 - 19:02
Hi. I got it and I would definately say its capacitive. I have a big problem though. I decided not look at changing the ROM just yet and followed Gerrys steps to installing android market. I managed to install everything fine and it worked. Then I tried to upgrade to the 3.4.4 I believe. Now the tablet is stuck in an Archos loading loop. I feel sick. Please help.
125 Guest(s)
Devices in use: Desktop (116), Phone (8), Tablet (1)
teverde
moradmin
DokMan
luisrubio21
dcatalan
dshepp
Topics: 6028
Members: 261295
