usb not working.
omnacron
Forum Posts: 15
2012/07/28 - 16:54
hello, im running into a problem i cannot get my usb to work on my tablet im running the in FreakTab finless v1.4 im trying to find were to turn on the usb debugging but i cannot find the option any where any help would be welcome.
Thanks Received: 264
2012/07/28 - 17:00
settings/apps/development
this is the classical path
omnacron
Forum Posts: 15
2012/07/28 - 17:05
it seems that my usb isnt working at all i did what you said and i turned it off then back on but to it did nothing
omnacron
Forum Posts: 15
2012/07/28 - 17:59
im not ure what is going on im wanting to upgrade to the finless 2.1 rom but i can not get my usb to turn on on my tablet. its like the usb its self is turned off is this even possiable. i dont think my cable in broken as im very carefull with my cables (with a family of 5 cant afford to replacem fom carelessness). any help on this problem would be great.
it worked the last time i used the usb which was to install the 1.4 rom but i have not needed to use the usb since then.
Thanks Received: 3169
2012/07/28 - 20:27
Maybe it's worth flashing back a firmware where you had USB working and see if it's still the case.
86 Guest(s)
Devices in use: Desktop (79), Phone (7)
peaches51
alejiitoo95
mustafaemreozmen
manpuiu
mbruno
Sochn
