2012/03/01
well im going to try and upload a picture if possiable im not sure if i have the rights to do so. but i found the mic no wonder the sound quality sucks its just soldered to the board with no hole for sound to reach other then it passing through the case. also i think i found the wireless antenna just a little peice of metal sticking out of the top of the pcb.
On my 7c g3 i have a little patch and that`s the WiFi antenna, but i do get decent signal
2012/03/01
im hopeing to increase my signal by attaching a better antenna i have a 8 db antenna i want to connect but not sure which solder point i should hook it to. my tablet will only get signal no more then a room and a half before it gets flaky so just trying to increase performance. specially since im on the road alot for work and i stop and use open wifi allot.
58 Guest(s)
Devices in use: Desktop (53), Phone (5)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
