gingerbreak did'nt work
tattman65
hendersonville tn.
2012/04/22 - 06:19
well i downloaded gingerbreak ran it   looked liked things were happening ran root check it said  not rooted  so now what any suggestions ?  thanks in advance Laugh
Thanks Received: 3169
2012/04/22 - 15:21
One possible way to check if Gingerbreak worked is use a an adb shell and type su, you should get a # prompt.
Root check tools usually check if/system partitions can be written to confirm you are rooted, which won't happen even if you root your device, as /system resides in a CRAMFS (read only partition) partition on the default firmware from the manufacturer.
Depending on what you need root for, you can also use a custom firmware for your tablet that will have root thru su binary and Superuser app to control the access and a fully writable system partition in ext3/ext4...
Currently Online: BigMihca, -wall-
136 Guest(s)
Devices in use: Desktop (122), Phone (15), Tablet (1)
neeldes123
yoyo33
doc747
DiVaK
dominik539
DarkWesc
Topics: 6010
Members: 260651
