10b G2.... Silly Question that needs answer please?
Kaci
Forum Posts: 11
2012/03/13 - 07:58
In what folder or such are the basic sounds located that are already preloaded? Can I access them not having root? I ask only because I want to add a couple of sounds I can use for some apps and they will only let me select from the list of preloaded ones. I seem to remember from my Android Phone that there was an "android" folder they were located in and if you loaded to there any extras that they would show in the list. Thanks in advance for any help. Also, what is the differences in certain apps from Android Market v. Amazon Appstore? I can use the WSYX6 app from Amazon Mkt., but if I d/l the same app from Google Market and try to use it it crashes (Same app, same provider, same version). Something weird abt that. Smile
Currently Online: joystick123, tarn
100 Guest(s)
Devices in use: Desktop (91), Phone (11)
tarn
johnmartin7042
madjid
robertmonroe
maxteslenko
shpub
Topics: 6034
Members: 261866
