Very weak built-in microphone on Arnova 10
buddy451
Forum Posts: 13
2011/12/02 - 21:11
The microphone built-in to the Arnova 10 doesn't have much sound pick-up, at least mine doesn't. When I record a video with the front-facing camera the sound is so low I just can't hear much of it at all. Is there any way to increase that sound level? Does anyone else have a similar problem? Are there any work-arounds? Right now, with a too-weak microphone, it makes it pretty hard to record a video to send in an e-mail because it is just too hard to hear.
Thanks Received: 3169
2011/12/02 - 21:25
I totally agree, the microphone is quite poor.
I believe the microphone is under the tiny hole at a lower left end of the tablet front, it's  probably connected with a very low end microphone component to give such bad quality sound and low volume.
To my knowledge there isn't any software solution for that [Image Can Not Be Found] and a bluetooth headset won't be an option considering there is no bluetooth support on the Arnova devices.
I am affraid we'll have to deal with it. We should actually highlight that detail in our product reviews, as it can be important for some users.
Any suggestion is welcome...
Airlock
2012/01/02 - 21:20
I spoke to the guys in maplins and they suggested a mic/headset might work, but an external mic plugged into the headphone jack or usb mic wouldn't...
Anybody tried these???
118 Guest(s)
Devices in use: Desktop (110), Phone (8)
mipolloverde
debaulieu
dimpapadop
teddybar
Kosak0
mertenschrist
Topics: 6030
Members: 261575
