Overclock or unlock CPU
Related Tags
iliasrc31
2011/11/03 - 14:14
As i have found on the net the Rockchip RK2818 that the arnova 10 uses is capable at 622MHz .The arnova 10 is limited at 300 mhz .
Is there any way to unlock the CPU or Overclock it ?
I have installed the custom firmware android 2.2.1 that you provide.
Thanks Received: 3169
2011/11/03 - 14:26
The CPU should run at 600 MHz, many tools report it at 300 MHz, it's very possible that they are inacurate or they just report the "idle" speed. I'm not sure about the proper way to measure the CPU speed on these machines.
Regarding overclocking, it has been reported to be doable with Cpubooster application, it did not work for me.
We will maybe seen some kernel tweaking in the future with CyanogenMod7 port work for the Arnova devices.
iliasrc31
2011/11/03 - 14:49
Every overclock app i have used dont work . The same benchmark results every time.
I believe is kernel issue. I ll wait for the CM7 rom.
Currently Online: izemnagh
106 Guest(s)
Devices in use: Desktop (91), Phone (14), Tablet (2)
celinedeuxsevres
15djamal15
Mansonforever
painor
izemnagh
evas1on
Topics: 6015
Members: 260837
