Arnova factory reset setting.
shrikant borole
2012/06/08 - 07:41
        Actually I am facing one problem with my tab,which is as fallows. When I used to turn on my tab,it provide me an option to"Complet action using" and give three option i.e 1.com.android.provision.DefaultActivity
2.Setup Wizard And
third Use by default for this action.
               After this I am unable to do anything...means its touchscreen don't work.I tried for factory reset,but was to get recovery mode.For long time if I used to follow your factory reset procedure then screen of tab used to blink or you can say it flickers.I necessary I can send you photo of it,if you are unable to understand the problem.
               Please suggest solution as early as possible.
               Thanking You.
Thanks Received: 3169
2012/06/08 - 08:33
You can try to flash the firmware, get it from here: http://www.arctablet.com/blog/featured/arnova-firmwares-updates/
and follow the flashing procedure from here: http://arnovatech.com/support/firmware.html?country=us&lang=en&g=2
Try connecting a mouse to the USB host port if you lost touchscreen access.
Else just flash using Rockchip tool: http://www.arctablet.com/blog/archos-tablet/flashing-firmware-rockchip-cpu-based-devices-archos-ht-7-8-arnova-10/
Eric
2012/08/28 - 15:21
Dear Admin,
I have a question. My kid bought the Childpad and forgot the "password" (the thing with the lines). Do you know how to put the device back to factory settings in a way that the "password" is gone?
Thanks in advance
113 Guest(s)
Devices in use: Desktop (93), Phone (19), Tablet (1)
marcammi
Home_R
safiris
witosizum
shakil
sp2
Topics: 6030
Members: 261433
