Arnova 10 Error :-(
AppleInTheMud
2012/11/18 - 15:50
Just got my self an Arnova 10 - 4 GB
Not completely sure what model it is. But it as a resitive touchscreen. Not glass. And on the back it says A101b (The 1b written smaller next to the A10)
Worked when I got it yesterday, but now it says when it just comes to the calibration screen.:
Sorry.:
The Process android.process.acore is stopped Try again.
Tried downloading new firmware then from Arnova and it finds it, but  says. "Found not valid diskimage - want to delete it?"
Sometimes I can go to the Homescreen but still with the error message in front. Then all freezes.
Help please ? :-)
AppleInTheMud
2012/11/18 - 15:52
Oh yea. And I cant enter the recovery mode.
Tried to do as they say on their support site, but that doesnt work.
Tap and hold reset with paperclip.
Plug ac-adapter.
Press volume + twice then pause... twice then pause... It just goes back to the same... :-(
Thanks Received: 3169
2012/11/18 - 16:18
You'll first need to clearly identify which model you have.
I assume it's a first generation Arnova since you didn't report there is G2 or G3 info in the product name.
Please check our Arnova 10 and Arnova 10b pages to confirm which model you have.
http://www.arctablet.com/blog/category/devices/arnova/arnova-g1/arnova-10/
http://www.arctablet.com/blog/category/devices/arnova/arnova-g1/arnova-10b/
AppleInTheMud
2012/11/18 - 16:22
Thank you :-) This one was easy. The box only says 10 and not b. So Im pretty sure it's a 10 and it has Android 2.1 so must be the 10.
AppleInTheMud
2012/11/18 - 16:42
I have the right image now and it finds it. But i cant hit install cos it has the other error message on top :-/
2012/11/18 - 17:54
Are you sure you picked the right image ?
This is the one for the Arnova 10 (resistive model) ?
http://arnovatech.com/support/firmware/1/arnova10/111117/update.img
AppleInTheMud
2012/11/19 - 01:00
Yes im sure. It says Install - but I cant push Install because the other error message is above the install message
Currently Online: Djomla88
93 Guest(s)
Devices in use: Desktop (80), Phone (12), Tablet (2)
Djomla88
darkfly13
SONNY4669
borodachuk
h10101010
Vlad7Serg
Topics: 6011
Members: 260690
