Wifi and Internal Storage
oldduck
Forum Posts: 21
2011/11/28 - 04:41
Thanks to Admin and the Rockchip Flashing Tool, my 10 G2 is reborn! [Image Can Not Be Found] Just follow the procedure to hold the reset button with volume up button for 15 seconds then let go, then the Rockchip program can detect the device and install the driver.  After that, loading the update.img to the device and start the flashing process.  It may take 10-20 minutes after the reboot to finish the initial setup of the new firmware, just be patient.
Report from the Titanium Backup, my Arnova now has 118 app elements (system apps + user apps) internal memory still has 27MB free [Image Can Not Be Found]
The free internal memory level is somehow in marginal level, now it has to be careful when downloading more apps, better be patient and wait for the solution to fix the small size of /data partition issue [Image Can Not Be Found]
57 Guest(s)
Devices in use: Desktop (53), Phone (4)
jacksonrid
