web pages
paul
Forum Posts: 18
2012/01/05 - 22:45
Hi, my fist posts! Web pages are not showing images on my Arnova 10g2, I'm sure they were when I got it just over a week ago (Christmas prezzy)Embarassed
Thank youLaugh
2012/01/05 - 23:10
Can you be a little more specific ? Is the tablet connected to the Internet ? Do you get an error message while trying to access a webpage ?
paul
Forum Posts: 18
2012/01/05 - 23:19
Hi yes sorry, the 10G2 is connected via wifi, no errors just blank space where images would be, if that's any help?
thank you
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/05 - 23:27
Depending on what browser you use, you can have settings for blocking images totally or having flash on demand. I suggest that you try to install a different browser to the one that you are having trouble with.
Try downloading Dolphin Hd or Opera from Appslib or Android market to see if your problem is still exists and check in the settings for the above mentioned. Images are always on but you may find that flash will have to be enabled for the web pages to load them immediately otherwise simple click the empty space on the site, usually indicated with an arrow where the flash content is.
If all else fails go onto the Arnova website and install the latest firmware that is one there as there has been an update to the firmware that will be on your tablet.
paul
Forum Posts: 18
2012/01/05 - 23:37
thank you, i will give it a go, I have Opera and the browser that came with it,
thanks,
paul
Forum Posts: 18
2012/01/06 - 13:50
many thanks, all sorted now the show pictures box was not ticked in browser
thank you
70 Guest(s)
Devices in use: Desktop (58), Phone (12)
jacksonrid
