2011/10/16
Seem to be having problems when plugging in a Usb storage device or memory stick.
When I plug one in the full Usb connector on the side I get the notification come up saying USBMassStorage safe to remove.
I have gone into settings/applications/development and de selected USB Debugging but still get the notification come up to remove it as soon as I put it in.
It is fine connecting it to my PC I can put files onto it that way, but can somebody suggest what I seem to be doing wrong!
2011/12/10
OK I just tried it myself since I had not tried plugging in a USB memory stick on my 10 G2 yet. When I plugged it in I got a notification saying "Turn off USB Mass Storage". Using the file browser I was able to browse the USB memory stick. The system did add the LOST.DIR to my memory stick. So I then unplugged the stick and got a notification saying "USB Mass Storage Unexpectedly Removed". I plugged the stick back in and this time went up to the notification and selected "turn off USB Mass storage". I got a pop up dialog to confirm and when I clicked OK it was told it was safe to remove my memory stick. So it appears on my stock G2 firmware with no root, the USB system is working fine. Are you runing the custom firmware?
Bob
57 Guest(s)
Devices in use: Desktop (53), Phone (4)
jacksonrid
