USB Host
max1912
2011/12/19 - 14:34
Hello!
This is my first post here.
I heard that the USB Host port will not work after firmware upgrade. Can you confirm it ?
max1912
2011/12/20 - 22:35
can't anyone answer me ?CryCryCry
ravinderrainger
2012/01/13 - 20:11
just read your post. I updated my firmware and now can access android market ( not all apps ) but have lost usb connectivity to my pc.
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/13 - 20:46
Have yet tried to pull down the notification bar at the
Top of the screen when your tablet is plugged
Into your pc it should reveal connect USB
finless
Stanton, Ca
Forum Posts: 604
2012/01/13 - 21:57
Yes in my ROM I turned on USB debugging by default. You can go into settings and turn it off.  Then you will ALWAYS get the USB connect screen when you plug in the USB cord.
But with it on whenever you plug in the USB cord it may or may not pop up the USB connect screen.  If it does not then you need to pull down the status bar and tap on USB connection.  Now you will see the screen to turn it on or off.
Bob
max1912
2012/02/04 - 16:44
thank's for your answers guys
max
137 Guest(s)
Devices in use: Desktop (120), Phone (15), Tablet (2)
mipolloverde
debaulieu
dimpapadop
teddybar
Kosak0
mertenschrist
Topics: 6030
Members: 261575
