Try the RK Driver Assistant: http://crewrktablets.arctablet.com/?wpfb_dl=1187
Execute de-install first.
Decompress with 7zip and run DriverInstall.exe.
2013/10/12
cheers oma for some reason the exe never decompressed.
sorry to be a pain but I have everything setup now and have run rk assistant I still cant connect my device to rockchip would it be best to try a different usb cable.Thankyou for your help I am a middle of the rangfe tech guy learning my trade lol
On which OS are you?
Ok, should be no problem. Pls use an USB2.0 port.
Do you know the right key combination to start the tab into flash-modus?
- Oma-
Newer tabs have USB3.0 ports (coded with blue color in the middle). Driver will not work on these ports.
Run the Flashtool with admin rights (click right).
Which Flashtool is it? RKBatch or RKAndroid? From where is the firmware?
49 Guest(s)
Devices in use: Desktop (39), Phone (10)
