2011/11/23
Hello all 🙂
I just bought Archos Arnova 10 G2 few days ago and till now I would say I kinda satisfied with the device. But since we are here on XDA, enjoyment from this device could be even better 😉
I tried to put a custom rom (here) to my device but unfortunatelly I'm not a lucky guy and device didn't boot at all. So I ask uncle Google for help and found this great tool that allowed me to root the tablet easily and put some extra apps into /system/app. I then encounter endless problems with Maket to even get it to work and found a way here (download the attached .zip, copy it to the device and install .apk's in order posted, reboot the device and you have Market and Google apps up and running ;)). And this is where my problems started to appear…
Market in that .zip is veeery old (v1.82) so I put there new version (3.3.11) and it seems to work well too but just until I try to install some app from Market => FC.
I read something about permisions set wrong or some another component/app is not installed or incompatible with Market 3+ (btw, only version working is 1.82 and 3.3.11 -with problems. Another version give my FC during loading).
So, now to the point 🙂 I managed to get some feedback from LogCat when Market FC:
D/Finsky ( 1912): [1] DownloadRestarterRule.run: Recovering from Market exit when restoring / downloading assets.
D/Finsky ( 1912): [1] SanityChecker.run: # LocalAssets corrected : 1
D/Finsky ( 1912): Sanity check took : 24 ms
D/Finsky ( 1912): [1] DownloadTickleReceiver.onReceive: Received tickle.
W/Finsky ( 1912): [1] DownloadTickleReceiver.generatePackageProperties: Received refund period time end string : null
D/Finsky ( 1912): [1] DownloadTickleReceiver.parseObb: Not generating OBB (patch false)
D/Finsky ( 1912): [1] DownloadTickleReceiver.parseObb: Not generating OBB (patch true)
D/Finsky ( 1912): [1] Installer.downloadAndInstallAsset: Downloading and installing Google Docs.
D/Finsky ( 1912): [1] DownloadImpl.setState: com.google.android.apps.docs from null to UNQUEUED.
D/dalvikvm( 1912): GC_CONCURRENT freed 404K, 52% free 2884K/5895K, external 793K/1051K, paused 4ms+3ms
D/Finsky ( 1912): [1] DownloadQueueImpl.add: Download com.google.android.apps.docs added to DownloadQueue
D/Finsky ( 1912): [1] DownloadImpl.setState: com.google.android.apps.docs from UNQUEUED to QUEUED.
I/installd( 60): free_cache(2618907) avail 195815424
D/Finsky ( 1912): [23] DownloadRecords.initializeAndPrune: Pruned 0 old downloads from the cursor.
D/Finsky ( 1912): [1] DownloadQueueImpl.startDownload: Download com.google.android.apps.docs starting
D/Finsky ( 1912): [1] DownloadRestarter.onPostExecute: Recovering restore of com.stumbleupon.android.app
D/Finsky ( 1912): [1] DownloadRestarter.handleObbResumingOrRestart: No OBB's associated to this asset.
D/Finsky ( 1912): [1] DownloadRestarter.restartAssetDownload: Restarting asset download : com.stumbleupon.android.app
E/DatabaseUtils( 269): Writing exception to parcel
E/DatabaseUtils( 269): java.lang.SecurityException: Invalid value for is_public_api: null
E/DatabaseUtils( 269): at com.android.providers.downloads.DownloadProvider.enforceAllowedValues(DownloadProvider.java:686)
E/DatabaseUtils( 269): at com.android.providers.downloads.DownloadProvider.checkInsertPermissions(DownloadProvider.java:624)
E/DatabaseUtils( 269): at com.android.providers.downloads.DownloadProvider.insert(DownloadProvider.java:442)
E/DatabaseUtils( 269): at android.content.ContentProvider$Transport.insert(ContentProvider.java:198)
E/DatabaseUtils( 269): at android.content.ContentProviderNative.onTransact(ContentProviderNative.java:146)
E/DatabaseUtils( 269): at android.os.Binder.execTransact(Binder.java:320)
E/DatabaseUtils( 269): at dalvik.system.NativeStart.run(Native Method)
W/dalvikvm( 1912): threadid=21: thread exiting with uncaught exception (group=0x40015560)
E/AndroidRuntime( 1912): FATAL EXCEPTION: download-manager-thread
E/AndroidRuntime( 1912): java.lang.SecurityException: Invalid value for is_public_api: null
E/AndroidRuntime( 1912): at android.os.Parcel.readException(Parcel.java:1322)
E/AndroidRuntime( 1912): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:160)
E/AndroidRuntime( 1912): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:114)
E/AndroidRuntime( 1912): at android.content.ContentProviderProxy.insert(ContentProviderNative.java:408)
E/AndroidRuntime( 1912): at android.content.ContentResolver.insert(ContentResolver.java:606)
E/AndroidRuntime( 1912): at com.google.android.finsky.download.DownloadManagerImpl$1.run(DownloadManagerImpl.java:44)
E/AndroidRuntime( 1912): at android.os.Handler.handleCallback(Handler.java:587)
E/AndroidRuntime( 1912): at android.os.Handler.dispatchMessage(Handler.java:92)
E/AndroidRuntime( 1912): at android.os.Looper.loop(Looper.java:123)
E/AndroidRuntime( 1912): at android.os.HandlerThread.run(HandlerThread.java:60)
D/dalvikvm( 1912): GC_CONCURRENT freed 408K, 51% free 3000K/6023K, external 793K/1051K, paused 4ms+3ms
D/dalvikvm( 79): GC_CONCURRENT freed 1041K, 49% free 5163K/10055K, external 1908K/1998K, paused 3ms+12ms
D/dalvikvm( 1912): GC_CONCURRENT freed 540K, 52% free 2994K/6151K, external 793K/1051K, paused 3ms+9ms
D/Finsky ( 1912): [1] Installer.downloadAndInstallAsset: Downloading and installing StumbleUpon.
D/Finsky ( 1912): [1] DownloadImpl.setState: com.stumbleupon.android.app from null to UNQUEUED.
D/Finsky ( 1912): [1] DownloadQueueImpl.add: Download com.stumbleupon.android.app added to DownloadQueue
D/Finsky ( 1912): [1] DownloadImpl.setState: com.stumbleupon.android.app from UNQUEUED to QUEUED.
D/dalvikvm( 269): GC_EXPLICIT freed 58K, 53% free 2654K/5575K, external 793K/1051K, paused 93ms
I/Process ( 1912): Sending signal. PID: 1912 SIG: 9
W/InputManagerService( 79): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@407a9570
I/ActivityManager( 79): Process com.android.vending (pid 1912) has died.
Can somebody advice me in which direction should I look to fix these errors?
Or another thing, /system is not RW on this device, so every change I do I have to flash whole ROM again :/
I tried these command in Terminal Emulator but without luck:
su
mount -o rw,remount -t yaffs2 /dev/block/mtdblock4 /system
Thanks anyone for kick 🙂
Regards
Adam
You may interested in checking this firmware and procedure:
http://www.arctablet.com/blog/featured/arnova-10-g2-first-custom-firmware-market-root/
It has a working Market support and read/write on /system.
Main issue on this firmware is the small size /data partition, need some tweaking in parameter file in the rockchip firmware...
Apps wise, the archive for CyanogenMod 7 should do fine.
http://cmw.22aaf3.com/gapps/gapps-gb-20110828-signed.zip
2011/11/23
If I add some of the files from that .zip file to the /system image, device didn't boot anymore (ARNOVA logo is blinking).
I'm trying to add "OneTimeInitializer.apk", "GoogleServicesFramework.apk" and "SetupWizard.apk". However, I D/L some unpacked native 2.3.1 image and these files are there stored with .odex files too. Adding this files make the device boot but Market 1.82 is FC upon opening (works only with the files stored here).
Can I somehow via adb connect to device when in recovery mode and look for some logs?
Thanks 🙂
I don't know where to look to get logs while in recovery mode.
Just a small lead, but I just found out there is a 4 GB and a 8 GB model for the Arnova 10 G2.
It well could be that our firmware made for the 8 GB model doesn't boot on the 4 GB model because the memory mapping is different. Can you please confirm you model you have ?
If it's the 4 GB model, can you upload your HWDEF and parameter files from the firmware just for checking.
2011/11/23
I also have 8GB model (small sticker on the back said: SC112804205 8GB). I'm not quite sure how to get HWDEF and parameter files, if you could point me I will upload them. Or if there is anything else you want from me to try just let me know 🙂
Btw, I checked the original spanish thread and on page 7 is another firmware with Market 3.3 already attached and its working 🙂 But /system is still not RW :/
p1ceus said:
btw, don't you guys know how to enter this recovery? Thanks
Enter:
adb boot recovery
from the command line on your computer having a functionning adb connection to the device.
parameter file is one the files you get when you unpack the update.img file, it describes some settings on the image file including some partition mapping.
I got confused with earlier models (RK2818 based), there is no HWDEF file on RK2918 tablets, only parameter file.
2011/11/23
Thanks for the command, I will try it when get home…
Here is the parameter file:
FIRMWARE_VER:0.2.3
MACHINE_MODEL:AN10G2
MACHINE_ID:007
MANUFACTURER:RK29SDK
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 2929
CHECK_MASK: 0x80
KERNEL_IMG: 0x60408000
CMDLINE: console=ttyS1,115200n8n androidboot.console=ttyS1 init=/init initrd=0x62000000,0x500000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),
0x00002000@0x00008000(boot),0x00004000@0x0000A000(recovery),
0x00080000@0x0000E000(system),0x00082000@0x0008E000(backup),
0x0003a000@0x00110000(cache),0x00080000@0x0014a000(userdata),
0x00002000@0x001ca000(kpanic),-@0x001cc000(user)
68 Guest(s)
Devices in use: Desktop (56), Phone (12)
jacksonrid
