No power, boot, lights after first battery drain. Custom firmware installed.
Related Tags
mrcabdrv
2012/01/06 - 07:29
I installed the custom firmware (for marketplace access) a couple of weeks ago, shortly after the unit's first use. Everything went fine and it worked great for multiple tests (web, apps, video, etc). It'd been restarted and shut down a handful of times. I sent the gift to my father who also used it no problem via AC and battery until the battery did it's first die. Since then he has no power, boot, lights, etc. Seems dead.
We have no way of reverting back to factory without addressing the problem at hand. Surely it's under warranty (extended service plan via SageMax), but it has the custom firmware on it... Any ideas? Maybe SageMax won't notice the firmware upgrade, not being the manufacturer, addressing the dead unit?
Any help would be great. I thought I might have to dick around with re-flashing/warranty work one day...not a couple weeks after he got it. Figured a new topic was fine as I think this is different than "bricked" after firmware install?
mobius
Forum Posts: 11
2012/01/10 - 19:04
Does the charging LED light up when AC power is connected? it could be that the power socket is broken as this happened to mine. Check the socket has a small centre pin present, if not it is damaged and will need to be replaced.
This is a repair you can do yourself if you are handy with a soldering iron. I sourced a suitable socket via Ebay.
Hope this helps.
2012/01/11 - 00:09
Soldering a broken power socket is quite easy to do.
Here is the outside picture of the plug I installed on my Arnova 10 (first gen model).
arnova10_connector_soldered_DSC_0087.jpgImage Enlarger
I'll try to find the inside pictures I did when soldering, if it is of any help...
mrcabdrv
2012/01/12 - 04:20
Hey, guys.
Thanks for the help. I'll keep it all in mind; however, my father's tablet is now operational again from a combination of doing a reset in the pin-hole and/or re-aligning the two-prong North American adapter at the end of the power adapter. He's unsure which one did it, but it is up and running. Potential false alarm. But, again, thanks a lot!
Steve
ray3324
2012/01/13 - 14:54
Hi All,
I'm a noob to all this Android gadgetry and was a victim lately to a Bricke Arnova 10 g2.Custom upgraded, go launcher ex and not much in internal storage left before the Brick incident!Battery had completely discarged and when plugged in the light was GREEN. I think this means that the machine is not receiving a charge for some reason as when I finally managed to unbrick it the charge is always RED. May be significant, dont really know.
Followed the directions on the other forum page to reset.
I went through a real nightmare trying to reset and after many hours of sticking a drawing pin in the reset hole and sreaming at the PC for not doing a three beep tone I finally got the thing to reset.
Here's how I did it on a windows Vista PC for anyone who's had the same problem:
Downloaded Arnova update file
Downloaded and extracted Batch file and run it, linked in the update file
Power in, usb linked, safety pin for reset at the ready
Hold down the volume up button
Press pin into reset - 5 secs or so ( wait for pc to identify a link)
Take pin out but keep holding volume up, apparently until you hear a three beep tone which indicates the Arnova is in reset mode. This never happened for me and drove me crazy!
On the Batch program clicked update, waited for the % to finish and everytime it was 'Checking upload' it would say that it failed. I tried this soooo many times and it kept happening.
Strangely once it said failed I disconnected the power and usb and pressed power on the Arnova, it powered on briefly for a second then shut off again.
I went through the hole process of reset again (still said failed on Batch) and this time as soon as it switched on I put the power cord in quickly, this for some reason allowed the Arnova to reset and format then count down to a reboot.
It then still did not just switch on! So, then I just hooked up the usb again but did NOT reset. Done an update on the Batch program again and to my amazment it completed for the first time.
I done the same as before, disconnect all cables, switch on Arnova, plug in power, wait very very patiently for the machine to reset and reboot and then finally come to life. It stayed on boot screen for a little while and then was back to working condition.
I believe there to be a fault with the battery as I had no problem with it or the firmware custom update until the battery had completely depleted. So, i'm going to make sure i dont run the battery down again.
Hope this will help at least one unfortunate soul in the same situation.
Oh, one more thing, the custom firmware is really good and I don't feel that it had much to do with the Bricking, i dont know too much on the technical side but it does seem more towards a battery problem on the Arnova.
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/13 - 15:13
Well Done Smile
With regards to battery please read through do and dont on this link
/blog/forum/arnova-10-g2-general/battery/
51 Guest(s)
Devices in use: Desktop (48), Phone (3)
jacksonrid
