Need help installing firmware
rakana
2011/12/21 - 21:10
Dear Admin,
I have arnova 10 G2, I installed a new firmware in my laptop and copy it to arnova, but I dont know wheres the root folder to start updating, plz can u tell me where I should copy the new firmware???
my tablet doesnt has arabic language, so can I install software to read and write arabic language???
thanks alot admin for your conern
finless
Stanton, Ca
Forum Posts: 604
2011/12/21 - 21:47
WHen you plug in the Arnova while powered up to your PC it will install 2 removable disks.  Open your My Computer icon and you will see a drive that says Arnova10G.  Open that and just copy update.img to that drive.  Do not open any folders!  Just copy straight to the drive.  Once it is copied simply unplug your USB cable and the Arnova will then prompt you that it found an update and ask if you want to install it.  Just follow the prompts.
Bob
124 Guest(s)
Devices in use: Desktop (114), Phone (9), Tablet (1)
teverde
moradmin
DokMan
luisrubio21
dcatalan
dshepp
Topics: 6028
Members: 261295
