2012/01/03
So last night i was using my arnova 10 g2 tablet, it died so i plugged in the charger to turn it back on. For about 5 min it was spazzing out and showing "arnova" repetitively that it usually does when it turns on i take out the charger and wait for it to die then put it back in, then i turn it on to discover that ALL of my apps, music, movies etc are gone including the android market (which i downloaded thru a rootless download on arctools) and appslib, not only that but now for what ever reason my tablet also says that i only have 27 mb out of 227 mb. This is impossible because it is a 4 gb tablet with a 8 gb memory card(which was also wiped) so what the hell happened!?? Has anyone else had this problem? is there anyway to get everything back?
Not sure about the cause of this problem but the repeated reboots with the Arnova logo does not look too good.Â
Recovering the data won't be easy, but you shouldn't worry about the storage space problem, the tablet probably shows the /data partition space which is usually in the 250 mb total.
I suggest you start again, by reflashing a firmware, either Arnova's default or a custom one.
Try the Rockchip Flashing tool, following procedure here:
/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/
and
85 Guest(s)
Devices in use: Desktop (79), Phone (6)
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
kfwacky
